Permutations combinatorics problem?
In summary, there are a total of 4,536 different telephone extensions with four digits and no repeated digits, where the first digit cannot be zero. This is calculated using the formula P(n,r)=n!/(n-r)! with 9 possibilities for the first digit and P(9,3)=9!/6!=9x8x7 for the last three digits. The final result is 9x9x8x7=4,536.
SMA_01
218
A telephone extension has four digits, how many different extensions are there with no repeated digits, if the first digit cannot be zero?
P(n,r)=n!/(n-r)!
For the first digit, there are 9 possibilities (because no zero)
For the last 3 digits I used P(9,3)=9!/6!=9x8x7
So, in the end my result was: 9x9x8x7= 4,536 different extensions...
I'm just wondering if I was correct?
P(n,r)=n!/(n-r)!
Seems fine to me.
FAQ: Permutations combinatorics problem?
1) What is a permutation in combinatorics?
A permutation is an arrangement of objects or elements in a specific order. In combinatorics, we use permutations to calculate the number of possible ways to arrange a set of objects.
2) What is the formula for calculating permutations?
The formula for calculating permutations is n!/(n-r)!, where n represents the total number of objects and r represents the number of objects being arranged.
3) Can you give an example of a permutation problem?
Sure, let's say we have a set of 5 letters (A, B, C, D, E) and we want to know how many different 3-letter combinations can be made. The answer would be 5!/(5-3)! = 60 possible permutations.
4) How is a permutation different from a combination?
A permutation takes into account the order of objects, while a combination does not. For example, ABC and ACB would be considered different permutations, but the same combination.
5) How can I use permutations in real life?
Permutations can be used to solve a variety of problems, such as calculating the number of different ways to arrange a set of numbers or letters, determining the number of possible outcomes in a game, or finding the number of possible combinations for a lock code.
