Permutations of 'MADHUBANI' Not Starting with 'M', Ending with 'I
  • MHB
  • Thread starter juantheron
  • Tags
    Permutations
In summary, we have 9 letters in the word $\bf{"MADHUBANI"}$, but we cannot start with $\bf{M}$ and must end with $\bf{I}$. To find the number of permutations, we first consider the case where the first letter is $A$, giving us $7!$ possibilities. Then, we consider the case where the first letter is not $A$ or $M$, giving us 5 choices for the first letter and $\frac{7!}{2!}$ possibilities for the remaining letters. Therefore, the total number of permutations is $7! + 5\bigl(\frac{7!}{2!}\bigr) = 20,160$.
juantheron
247
How many permutation of the letters of the words $\bf{"MADHUBANI"}$ do not begin with $\bf{M}$ but end with $\bf{I}$
I am not 100% sure that I am right here but want to give it a shot.
The starting word has 9 letter with two A's. The number of choices for the first letter is 7 though, because I must be used at the end and M cannot be first, so 9-2=7 choices are left. Now write the number of possible letter choices for the second letter. Again it can't be I but this time it could be M, and we must note that a some letter (not I or M) has been chosen for the first spot. 9-1-1=7 again. Try to continue this process until the end of the word.
Lastly, there are two letters A which are identical so when they switch positions but everything else remains the same, the word is the same and we can't double count. To correct for this error you divide the answer you got above by 2!.
If all the letters were different there would be \(8!\) permutations which end with I, of which \(7!\) start with M, so \(8!-7!=7.7!\) would not start with M but end with I. However there is a repeated A so the final answer is half that.
CB
Hello, jacks!
I'll give it a try . . .
We have the letters: .$ A,A,B,D,H,I,M,N,U.$
We want: .$\_\,\_\,\_\,\_\,\_\,\_\,\_\,\_\,I $
[COLOR=#be00e]n . . . . . . .[/COLOR]$\uparrow$
. . . . . . $\sim\!M$[1] The first letter is $A\!:\;A\,\_\,\_\,\_\,\_\,\_\,\_\,\_\,I $
. . .The remaining spaces can be filled in $7!$ ways.[2] The first letter is not $A$ and not $M\!:$
. . . $\_\,\_\,\_\,\_\,\_\,\_\,\_\,\_\,I$
There are 6 choices for the first letter.
. . . The remaining spaces can be filled in $\frac{7!}{2!}$ ways.Therefore, there are: .$7! + 6\left(\frac{7!}{2!}\right) \:=\:20,160$ ways.
Don't we need to divide [1] by 2! as well since we consider the cases when the A 's are switched to be the same?
If so, then you'd have \(\displaystyle \frac{7!}{2!}+6\left(\frac{7!}{2!}\right)\) that is \(\displaystyle \left( \frac{7 \cdot 7!}{2!} \right)\) which what CB and I got.
Would like confirmation on this :)
Both methods are correct, but there is an error in soroban's computation.
That red 6 should be a 5: if the first letter is not I, M or either of the two As, then there are only five other choices (count them: D, H, U, B, N). So soroban's count for the number of arrangements should be $7!+5\bigl(\frac{7!}{2!}\bigr)$, which agrees with the answer of Jameson and CaptainBlack.
FAQ: Permutations of 'MADHUBANI' Not Starting with 'M', Ending with 'I
What are permutations of "MADHUBANI" that do not start with "M" and end with "I"?
The permutations of "MADHUBANI" that do not start with "M" and end with "I" are as follows: "ADHUBANI", "ADHUBANI", "ADHUBANI", "ADHUBANI", "ADHUBANI", "ADHUBANI".
How many possible permutations are there for "MADHUBANI" not starting with "M" and ending with "I"?
There are 6 possible permutations for "MADHUBANI" not starting with "M" and ending with "I".
Can you provide an example of a permutation of "MADHUBANI" not starting with "M" and ending with "I"?
One example of a permutation of "MADHUBANI" not starting with "M" and ending with "I" is "ADHUBANI".
Is there a specific order for the permutations of "MADHUBANI" not starting with "M" and ending with "I"?
Yes, the permutations follow a specific order based on the letters in the word. The first letter in the permutation will always be "A" and the last letter will always be "I".
How do you calculate the number of permutations for "MADHUBANI" not starting with "M" and ending with "I"?
The number of permutations can be calculated using the formula n!/(n-r)!, where n is the total number of letters in the word and r is the number of letters that are not changing positions (in this case, 2).
