Perpendicular bisector question
In summary, the equation of the perpendicular bisector of the line segment with endpoints (x_{1}, y_{1}) and (x_{2},y_{2}) can be written as \frac{x-x^{-}}{y_{2}-y_{1}}+\frac{y-y^{-}}{x_{2}-x_{1}}= 0, where (x^{-},y^{-})are coordinates of the midpoint of the segment. However, the equation does not work when the line segment is parallel to x axis, and the perpendicular bisector is a line which goes through a point and perpendicular to a given direction.
mindauggas
127
(b) Show that the equation of the perpendicular bisector of the line segment with endpoints (x[itex]_{1}[/itex], y[itex]_{1}[/itex]) and (x[itex]_{2}[/itex],y[itex]_{2}[/itex]) can be written as [itex]\frac{x-x^{-}}{y_{2}-y_{1}}[/itex]+[itex]\frac{y-y^{-}}{x_{2}-x_{1}}[/itex]= 0, where (x[itex]^{-}[/itex],y[itex]^{-}[/itex])are coordinates of the midpoint of the segment
Because:
(1) [itex]\frac{x-x^{-}}{y_{2}-y_{1}}[/itex]+[itex]\frac{y-y^{-}}{x_{2}-x_{1}}[/itex]= 0
We have:
(2)[itex]\frac{x-x^{-}}{y_{2}-y_{1}}[/itex]=-[itex]\frac{y-y^{-}}{x_{2}-x_{1}}[/itex]
Does this the minus sing in front of the term on the right side of the equation express the relative slope of the perpendicular bisector? (Relative to the line segment).
I also realized that the perpendicular bisector formula does not work, or it seems to me, when line segment is parallel to x axis, hence y=y[itex]^{-}[/itex] which makes the first term undefined. Hence the formula does not work when the line segment is perpendicular to the y-axis for similar reason.
Yeat still I don't know how to show the equation to be true in special cases where y[itex]\neq[/itex]y[itex]^{-}[/itex]
I reason than symmetry has to be somehow involved, but is it?
That perpendicular bisector is a line which goes through a point and perpendicular to a given direction. (which point, what direction?) What is the general formula of a straight line?
ehild
ehild
(1) it goes through the mid point of the given line segment ... in my case it's coordinates are (x[itex]^{-}[/itex],y[itex]^{-}[/itex])
(2) it is perpendicular to the direction of the line segment (x[itex]_{1}[/itex],y[itex]_{1}[/itex]) to (x[itex]_{2}[/itex],y[itex]_{2}[/itex])
(3)the general formula of a straight line has many forms, but, presumably, you are talking about [itex]y=mx+b[/itex] (the slope-intercept form)
Probably i would get more use out of the "intercept form":
[itex]\frac{x}{a}[/itex]+[itex]\frac{y}{b}[/itex]=1 ... ?
I vote for the first one. :smile: Can you find m?
And you were right, the given bisector equation does not work when the segment is parallel with one of the axis. So handle these cases separately.
ehild
[itex]y=mx+b[/itex]
[itex]y-b=mx[/itex]
[itex]\frac{y-b}{x}[/itex][itex]=m[/itex]
But m is just [itex]\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex]
So we have [itex]\frac{y-b}{x}[/itex]=[itex]\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex]
Don't know what to do next ...
Seems like this equation [itex]\frac{x-x^{-}}{y_{2}-y_{1}}[/itex]+[itex]\frac{y-y^{-}}{x_{2}-x_{1}}[/itex]= 0 is a amalgam of two slope expresions. This is confirmed by noticing that they are equal but opposite in sign ... but how to SHOW it ?
Also, the terms have to have the same numerical value ... also don't know how to show it.
(y2-y1)/(x2-x1) is the slope of the original line segment. The bisector is perpendicular to it. What do you know about the slopes of perpendicular lines?
ehild
Two non-vertical lines with slopes m1 and m2 are perpendicular if and only if the product their slopes is -1, that is:
(1) [itex]m1m2=-1[/itex]
But then I also know that the slope of P.B. is
(2) [itex]\frac{y-y^{-}}{x-x^{-}}[/itex] (since I only know that (y[itex]^{-}[/itex],x[itex]^{-}[/itex]) and (x,y) are points on it)
Combining (1), (2) and the slope of the line segment we get:
[itex]\frac{y-y^{-}}{x-x^{-}}[/itex]*[itex]\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex]=-1
Diving both sides by [itex]\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex] we get
[itex]\frac{y-y^{-}}{x-x^{-}}[/itex]=[itex]-1/\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex]
But this is the same as:
[itex]\frac{y-y^{-}}{x-x^{-}}[/itex]=-[itex]\frac{x_{2}-x_{1}}{y_{2}-y_{1}}[/itex]
and the same as the formula you had to derive. You have done it!
You can also write it in the form (x2-x1)(x-x-)=(y2-y1)(y-y-), and this is valid for any case. If y2=y1, the equation of the bisector is = (x-x-)=0, and it is (y-y-)=0 in case x2=x1.
ehild
Yes, I see now ... they are the same, because you can get one from the other just by algebraic manipulation.
Thank you very much :)
You are welcome.:smile:
ehild
Related to Perpendicular bisector question
What is a perpendicular bisector?
A perpendicular bisector is a line that divides a line segment into two equal parts at a 90 degree angle. It is also equidistant from the endpoints of the line segment.
How do you find the equation of a perpendicular bisector?
To find the equation of a perpendicular bisector, you need to use the midpoint formula to find the coordinates of the midpoint of the line segment. Then, you can use the slope formula to find the slope of the line segment. Finally, you can use the negative reciprocal of the slope to find the slope of the perpendicular bisector. Plug in the coordinates of the midpoint and the slope of the perpendicular bisector into the point-slope form or slope-intercept form to get the equation.
What is the relationship between perpendicular bisectors and right triangles?
Perpendicular bisectors are important in right triangles because they intersect at the circumcenter, which is the center of the circle circumscribed around the triangle. The circumcenter is also equidistant from the vertices of the right triangle, making it useful in finding the length of the hypotenuse or the location of the right angle.
How do you use perpendicular bisectors to construct a triangle?
To construct a triangle using perpendicular bisectors, you first need to draw the three perpendicular bisectors of the sides of the triangle. Then, where the three perpendicular bisectors intersect is the center of the circle that circumscribes the triangle. You can use this point as the center and the distance from the center to one of the vertices as the radius to draw the circumscribed circle. Finally, you can draw a line connecting the vertices of the triangle to the center of the circle to complete the triangle.
What are some real-life applications of perpendicular bisectors?
Perpendicular bisectors have many practical applications, including in architecture, engineering, and surveying. They are used to construct right angles, find the center of circles, and divide objects into equal parts. Additionally, they are used in the development of computer graphics and animations, as well as in navigation systems for vehicles and ships.
