MHB Perpendicular lines and the product of their slopes
When two lines are perpendicular, the product of their slopes equals -1, which can be derived from the angles of inclination of the lines. The angle of inclination for a line is determined using the tangent function, leading to the relationship that if one line's slope is m1, the other line's slope m2 must satisfy m2 = -1/m1. This relationship can also be demonstrated through similarity in triangles, confirming that m1 * m2 = -1. Additionally, alternative proofs using vectors and dot products are mentioned as more complex but valid methods. Overall, the discussion emphasizes the mathematical principles behind the slopes of perpendicular lines.
MarkFL
MHB
As students taking pre-calculus, you are probably aware that when two lines are perpendicular, the product of their slopes is -1. Let's see why this is.
Let one line be $\displaystyle y_1=m_1x+b_1$ and the other line be $\displaystyle y_2=m_2x+b_2$.
Now,we know the angle of inclination of a line is found from:
$\displaystyle m=tan(\theta)\,\therefore\,\theta=\tan^{-1}(m)$
Let $\displaystyle \theta_1$ be the angle of inclination of $\displaystyle y_1$ and $\displaystyle \theta_2$ be the angle of inclination of $\displaystyle y_2$.
Now, suppose $\displaystyle 0\le\theta_2\le\frac{\pi}{2}$ and $\displaystyle -\frac{\pi}{2}\le\theta_1\le0$.
If the two lines are perpendicular, then we must have:
$\displaystyle \theta_2=\theta_1+\frac{\pi}{2}$
Now, taking the tangent of both sides, we find:
$\displaystyle \tan\left(\theta_2 \right)=\tan\left(\theta_1+\frac{\pi}{2} \right)$
Using the identity $\displaystyle \tan\left(x+\frac{\pi}{2} \right)=-\cot(x)$ we have:
$\displaystyle \tan\left(\theta_2 \right)=-\cot\left(\theta_1 \right)$
$\displaystyle \tan\left(\theta_2 \right)=-\frac{1}{\tan\left(\theta_1 \right)}$
And so, we must then have:
$\displaystyle m_2=-\frac{1}{m_1}$
$\displaystyle m_1m_2=-1$
Comments and questions should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-perpendicular-lines-product-their-slopes-4218.html
This topic is for commentary pertaining to the tutorial:
http://mathhelpboards.com/math-notes-49/perpendicular-lines-product-their-slopes-2953.html
Here's another method using similarity. Consider the following diagram:
We can see that the slope of line $y_1$ is $$m_1=-\frac{\Delta y_1}{\Delta x_1}$$ and the slope of line $y_2$ is $$m_2=\frac{\Delta y_2}{\Delta x_2}$$
By similarity, we have:
$$\frac{\Delta y_1}{\Delta x_1}=\frac{\Delta x_2}{\Delta y_2}\implies \frac{\Delta y_1}{\Delta x_1}\cdot\frac{\Delta y_2}{\Delta x_2}=1$$
Hence:
$$m_1m_2=-\frac{\Delta y_1}{\Delta x_1}\cdot\frac{\Delta y_2}{\Delta x_2}=-1$$
Your second method is very fast! I remember coming up with my own proof using vectors and dot products, but it took a whole page. Your second method, it seems to me, has a good deal of pedagogical value.
Thank you...I stumbled upon that helping a student at another site to find the third vertex of a right triangle, when given two of the vertices in the plane, and the leg lengths. When I realized I had found a nice method to show the product of the slopes of perpendicular lines is -1, I raced here to add it to this topic. :D
