markoX
- 28
In quantum mechanics we learn that the states of a system described by eigen states which they are perpendecular. why should be this?
markoX said:In quantum mechanics we learn that the states of a system described by eigen states which they are perpendecular. why should be this?
DrFaustus said:markoX -> You have to recall the general framework of QM to understand the answer. And in particular what you should keep in mind is that in QM the state of a system is described by some vector in a Hilbert space. And Hilbert spaces have the nice property of having a scalar product, which you can use to define some "orthogonality". (In other words, change the scalar product and the notion of orthogonality changes.) And it is using this scalar product that you can construct an "orthonormal basis" that you then use to describe every other vector in your Hilbert space. Think of [tex] \mathbb{R}^n[/tex]. When you write a vector in [tex] \mathbb{R}^n [/tex] as [tex](x_1,x_2,\ldots,x_n)[/tex] you are writing its components with respect to some particular basis. And it is simply a matter of convenience to pick this basis as an orthonormal basis. But you could have used another, non orthonormal, basis to describe the same vector. (Of course, then it's components would change.) And the situation in QM is completely analogous. It is simply mathematically convenient to work with an orthonormal basis, which you use to "decompose" your state vector. But you could, in principle, use a non orthonormal basis. Only your calculations would be much more complicated.
maverick_starstrider -> What you say is a bit confused. You can always use a non orthonormal basis to decompose a generic vector. And such decomposition will always be unique, with no "overlapping projections". Think about the plane. As soon as you have two linearly independent vectors, you can write every other vector as a unique linear combination of the two given vectors. You can hence use them as your basis vectors. And the "projections" are then precisely the coefficients in the linear combination, and they are in no sense "overlapping".
markoX said:thanks for replies.
I will keep in my mind linguistic note.
yes that is right...It is esier to work with orthogonal basis.
ok...thank again.
maverick_starstrider said:Yes but in quantum we always use orthonormal basis states. If they're not orthonormal you use gram-schmidt until they are.
kanato said:No, not always. Several electronic structure codes use non-orthogonal basis states because it's actually more convenient to not orthogonalize the basis states (the commonly used LMTO basis is one such nonorthogonal basis). If you want basis states represented by hydrogenic type orbitals for atoms in a molecule or solid, then basis states on different atoms won't be orthogonal. If you orthogonalize them, you wind up mixing different basis states so that your new basis states don't have the same physical meaning of localized orbitals.
Also, Gram-Schmidt is not commonly used because it is not symmetric. A better approach is the Loewdin orthogonalization.
The term "perpendicularity" in quantum states refers to the mathematical relationship between two quantum states that are orthogonal, meaning they are at a right angle to each other. This is a fundamental property of quantum mechanics and is crucial in understanding how quantum systems behave.
The uncertainty principle states that certain pairs of physical properties, such as position and momentum, cannot be measured simultaneously with perfect accuracy. This is because the act of measuring one property can affect the other. Perpendicularity of quantum states is related to this principle because it allows for the existence of complementary, non-commuting observables. This means that the more certain we are about the value of one observable, the less certain we can be about the value of the other observable.
No, two quantum states that are not perpendicular cannot be considered basis states. Basis states are required to be orthogonal to each other in order to form a complete and orthonormal basis for a given vector space. This means that they must be at a right angle to each other, or perpendicular, to accurately represent all possible states of the system.
Superposition is the principle that a quantum system can exist in multiple states at the same time, until it is observed and collapses into a single state. The concept of perpendicularity of quantum states is essential in understanding how superposition works. When two states are perpendicular, they are completely independent of each other, and can coexist in a superposition. However, if two states are not perpendicular, they are not independent and cannot exist in a superposition.
Yes, the perpendicularity of quantum states is closely related to the concept of probability in quantum mechanics. The probability of obtaining a particular measurement outcome is given by the square of the inner product of the state vector with the corresponding basis state vector. This inner product is only non-zero when the two states are perpendicular, meaning that the perpendicularity of quantum states plays a crucial role in determining the probability of measurement outcomes.
