Perturbation first order hydrogen - Coulomb model
The discussion revolves around calculating the first-order correction for the ground state energy of a hydrogen atom under a modified Coulomb potential. The potential deviates from Coulomb's law at small distances, leading to a perturbation Hamiltonian that needs to be integrated. Participants emphasize the importance of using the correct volume element in spherical coordinates for the integration. The conversation also includes guidance on performing the integration step-by-step, suggesting substitution methods to simplify the calculations. Ultimately, the focus is on ensuring the integrals are set up correctly to arrive at a solvable form.
JaneHall89
Assume that there is a deviation from Coulomb’s law at very small distances, the Coulomb potential energy between an electron and proton is given by
V_{mod}(r)=\begin{cases}<br /> -\frac{q^{2}}{4\pi\varepsilon_{0}}\frac{b}{r^{2}} &amp; 0&lt;r\leq b\\<br /> -\frac{q^{2}}{4\pi\varepsilon_{0}}\frac{1}{r} &amp; r&gt;b<br /> \end{cases}
(a) Find the first order correction for the ground state using the standard integrals
Ground State - \psi_0=\frac{2}{a_0^{3/2}}e^{-r/a_0}
To find the first order correction - E_{1}^{(1)}=<ψ0| \delta\hat{\textrm{H}}|ψ0>
Perturbation - \delta\hat{\textrm{H}}=-\dfrac{q^{2}}{4\pi\varepsilon_{0}}\left(\dfrac{b}{r^{2}}-\dfrac{1}{r}\right) for 0<r≤b
Standard integrals
\int_{0}^{x} e-u du = 1 - e-x
-\int_{0}^{x} u e-u du = 1 - e-x - xe-x
Using E_{1}^{(1)}=\int_{-∞}^{∞}ψ(0) * \delta\hat{\textrm{H}} ψ(0)
E_{1}^{(1)}=\dfrac{1}{\pi a_{0}^{3}}\dfrac{q^{2}}{4\pi\varepsilon_{0}}\int_{0}^{b}(e^{\dfrac{-2r}{a_{0}}}) (\dfrac{b}{r^{2}}-\dfrac{1}{r}) dr
So I've taken the constants out and applied a 'sandwich integral' with the perturbation Hamiltonian... This problem is I have no idea where to start making this easier for me, I've been staring at it for aleast and hour. Can someone help please?
Where is the volume element for the integration ##d^3\mathbf{r}##?
r is radius not a vector in this question. So integration is only on radius. I added dr
That's not the point of my question. Any integral must take the form of ##\int f(x) \, dx##, where is your ##dx## in your calculation of the integral?
I added dr
JaneHall89 said:
I added dr
That's still not completely correct, you are integrating over the entire volume which means the integration element must be that of a volume element. Find the correct form of ##d^3\mathbf{r}## (sometimes also written as ##dV##) in spherical coordinate, for example take a look at https://en.wikipedia.org/wiki/Spherical_coordinate_system.
But the perturbation hamilton that I have is independent of Φ,θ
The form of the volume element is entirely determined by the coordinate system being used, not by the integrand.
E_{1}^{(1)}=\dfrac{1}{\pi a_{0}^{3}}\dfrac{q^{2}}{4\pi\varepsilon_{0}} \int_{0}^{2pi} \int_{0}^{pi}\int_{0}^{b}(e^{\dfrac{-2r}{a_{0}}}) (\dfrac{b}{r^{2}}-\dfrac{1}{r}) dr dθ dΦ
JaneHall89 said:
dr dθ dΦ
Still something missing, look for ##dV=?## in the wikipedia link above.
E_{1}^{(1)}=\dfrac{1}{\pi a_{0}^{3}}\dfrac{q^{2}}{4\pi\varepsilon_{0}} \int_{0}^{2pi} \int_{0}^{pi}\int_{0}^{b}(e^{\dfrac{-2r}{a_{0}}}) (\dfrac{b}{r^{2}}-\dfrac{1}{r}) r2sin θ dr dθ dΦ =
E_{1}^{(1)}=\dfrac{1}{\pi a_{0}^{3}}\dfrac{q^{2}}{4\pi\varepsilon_{0}} \int_{0}^{2pi} \int_{0}^{pi}\int_{0}^{b}(e^{\dfrac{-2r}{a_{0}}}) (b-r) sin θ dr dθ dΦ
Yes, that's right. Now all ##r##'s will be in the numerator and the integral should be analytically solvable.
hmm I'm still not seeing how to make use of the standard integrals given
I mean this equation:
E_{1}^{(1)}=\dfrac{1}{\pi a_{0}^{3}}\dfrac{q^{2}}{4\pi\varepsilon_{0}} \int_{0}^{2pi} \int_{0}^{pi}\int_{0}^{b}e^{\frac{-2r}{a_0}} (b-r) dr d\theta d\phi
Do the integrals over the angles first if the appearance makes obscure your mind. You will then be left with the integral over ##r##, which takes the form of the formula you posted under the "Relevant equations" in your starting post.
\int_{0}^{b}(e^{\dfrac{-2r}{a_{0}}}) (b-r) dr = \int_{0}^{b}-r(e^{\dfrac{-2r}{a_{0}}})+b(e^{\dfrac{-2r}{a_{0}}})
This is hurting me, I can't see how these work with standard integrals?? Everything I am trying on my paper is not working :/ Have I gone wrong somewhere else and that's why I can't see it
Integrate via a substitution using u=2r/a
One more time, don't leave the integration element behind whenever you write an integral.
As to the method to solve, do you know integration by substitution? It's the same as the one someone above suggested.
I have done the subs after a very long day of staring at this and I think its correct but its incredibly messing and hard to simplify.
For the first integral...
= ((a0b) /2) x (1-e-2b/a0)
Second
= (a02 / 4) x ( 1 - e - 2b/a0 - 2b/a0 e-2b/a0)
So I'll add them to complete.
I have Just to double check that the limits are from 0 to 2b/a0?
Yes, add them.
Why do you still want to double check again when you have computed the integral?
  • · Replies 36 ·
