Perturbation of Potential (Particle in a Box)
V_{1}|\psi_{n}^{0}\right> = \left(\frac{2\gamma}{L}\right)\left(\frac{-L^{3}}{8n\pi}\right)\left< \psi_{n}^{0}|V_{1}|\psi_{n}^{0}\right> = \left(\frac{-\gamma L^{3}}{4n\pi}\right)To get the expression for the two energy shifts, we substitute in n=1 and n=2:E_{1} = \left(\frac{-\gamma L^{3}}{4\pi}\right)E_{2}
Hart
169
Assume that the particle in the box is perturbed by a potential [tex]V_{1}(x) = x [/tex].
Calculate the energy shift of the ground state and the first excited state in first-order
perturbation theory.
Unperturbed wave functions for the particle given by:
[tex]\psi_{n}^{0}(x) = \sqrt{\frac{2}{L}}sin(\frac{n\pi x}{L})[/tex]
[Hint: This energy shift is given by the expectation value of the perturbation.]
Perturbation: [tex]H' = V_{1}(x) = \gamma x[/tex]
Correction to energy of 'n'th state is:
[tex]E_{n}^{0} = <\psi_{n}^{0}|V_{1}|\psi_{n}^{0}> = V_{1}<\psi_{n}^{0}|\psi_{n}^{0}> = V_{1}[/tex]
Therefore corrected energy levels defined as:
[tex]E_{n} \approx E_{n}^{0}+V_{1}(x)[/tex]
Don't know where to go from here..
What you have here is incorrect and meaningless. To begin with
[tex]E_{n}^{0} = <\psi_{n}_{0}|H^{0}|\psi_{n}^{0}>[/tex]
is the unperturbed energy.
Secondly, V1 is a function equal to γx and cannot be set equal to a constant, i.e. it cannot be pulled of the integral. Don't forget that
[tex]<\psi_{n}^{0}|V_{1}|\psi_{n}^{0}> = \int (\psi_{n}^{0})^*\:\gamma x \;\psi_{n}^{0}\;dx[/tex]
You need to do the integral correctly.
[tex](\psi_{n}^{0}(x))^{2} = \left(\sqrt{\frac{2}{L}}sin(\frac{n \pi x}{L})\right)^{2} = \frac{2sin^{2}(\frac{n \pi x}{L})}{L}[/tex]
[tex]<\psi_{n}^{0}|V_{1}|\psi_{n}^{0}> = \int \left( (\gamma x)(\frac{2sin^{2}(\frac{n \pi x}{L})}{L}) \right) dx[/tex]
[tex]<\psi_{n}^{0}|V_{1}|\psi_{n}^{0}> = \frac{2\gamma}{L} \int \left( xsin^{2}(\frac{n \pi x}{L}) \right) dx[/tex]
Is this now going along the right way?
It is. Now do the integral and see what you get.
[tex]\int \left( xsin^{2}(\frac{n \pi x}{L}) \right) dx = \frac{\left(\frac{x}{2}\right) -sin(\frac{2n \pi x}{L})} {(\frac{4n\pi}{L})}
[/tex]
[tex]
\int \frac{\left(\frac{x}{2}\right) -sin\left(\frac{2n \pi x}{L}\right)} {(\frac{4n\pi}{L})} = \left(\frac{-L}{4n\pi}\right) \int \left(\frac{x}{2}\right) -sin \left(\frac{2n \pi x}{L}\right) dx
[/tex]
[tex]
\int \left(\frac{x}{2}\right) -sin\left(\frac{2n \pi x}{L}\right) dx = \left( \frac{x^{2}}{2} \right) + cos\left(\frac{2n \pi x}{L}\right)
[/tex]
Therefore:
[tex]\int \left( xsin^{2}(\frac{n \pi x}{L}) \right) dx = \left(\frac{-L}{4n\pi}\right)[\left( \frac{x^{2}}{2} \right) + cos\left(\frac{2n \pi x}{L}\right)
[/tex]
.. where do I go from here? :S
What are your limits of integration?
This:
[tex]\int_{-\infty}^{\infty} \left( xsin^{2}(\frac{n \pi x}{L}) \right) dx = \left(\frac{-L}{4n\pi}\right)\left[\left( \frac{x^{2}}{2} \right) + cos\left(\frac{2n \pi x}{L}\right)\right]_{-\infty}^{\infty}[/tex]
Does the box extend from minus infinity to plus infinity?
Ah! No.. it goes from x=0 to x=L. Better put the limits in then! ..
[tex]\int_{0}^{L} \left( xsin^{2}(\frac{n \pi x}{L}) \right) dx = \left(\frac{-L}{4n\pi}\right)\left[\left( \frac{x^{2}}{2} \right) + cos\left(\frac{2n \pi x}{L}\right)\right]_{0}^{L}[/tex]
So:
[tex]
\left[\left( \frac{L^{2}}{2} \right) + cos\left(2n \pi \right)\right]
\left[1\right]
[/tex]
You forgot the normalization constant in front of the wavefunction. Also, can you simplify your expression?
Just multiplied everything together and simplified the expression, and got this:
[tex]
\left< \psi_{n}^{0}|V_{1}|\psi_{n}^{0}\right> = \left(\frac{2\gamma}{L}\right)\left( \frac{\left(2L-L^{3}\right)-2Lcos\left(2\pi x\right)}{8n\pi}\right)
[/tex]
And then just put in n=1 and n=2 to get the 2 expressions for energy shifts.
Try again. You are evaluating an integral from 0 to L. There should be no "x" in your expression. Also, the 2L - L3 term is dimensionally incorrect.
[tex]\left< \psi_{n}^{0}|V_{1}|\psi_{n}^{0}\right> = \left(\frac{2\gamma}{L}\right)
\left( \left(\frac{\left-L^{3}+L}{2}\right) -cos\left(2\pi n\right)}\right)\right)[/tex]
Your answer is still dimensionally incorrect. When you say (- L3 + L) you adding something that has dimensions of length cubed to something that has dimensions of length. You cannot do that and have an answer that makes physical sense. Check (or perhaps post) your integration steps; you must be dropping something along the way. Also, can you simplify cos(2πn)?
FAQ: Perturbation of Potential (Particle in a Box)
What is perturbation of potential in the context of a particle in a box?
Perturbation of potential refers to the small changes or disturbances in the potential energy of a particle confined in a box. This can be caused by external factors such as an electric field or changes in the boundaries of the box.
How does perturbation affect the energy levels of a particle in a box?
Perturbation can cause the energy levels of a particle in a box to shift and split into multiple levels. This is known as energy degeneracy and can result in the particle having different energy states and probabilities of being in those states.
Can perturbation of potential change the probability of finding a particle in a specific energy state?
Yes, perturbation can change the probability of finding a particle in a specific energy state. This is because the perturbation affects the energy levels and probabilities of the particle, leading to a redistribution of the probabilities among different energy states.
How does the strength of perturbation affect the energy levels of a particle in a box?
The strength of perturbation can greatly influence the energy levels of a particle in a box. As the strength increases, the energy levels become more split and the energy degeneracy increases. This can also affect the overall energy of the particle, causing it to increase or decrease depending on the direction of the perturbation.
Is perturbation of potential relevant in real-world applications?
Yes, perturbation of potential is relevant in various real-world applications such as quantum computing, solid-state physics, and atomic and molecular physics. It is also important in understanding the behavior of particles in confined systems, which has implications in materials science and nanotechnology.
