I Perturbation theory with two parameters?
Amentia
Hello,
I am looking for a reference which describe perturbation theory with two parameters instead of one. So far, I did not find anything on the topic. It might have a specific name and I am using the wrong keywords. Any help is appreciated.
To be clear, I mean I have ##H = H_{0}+\lambda_{1}V_{1}+\lambda_{2}V_{2}##, where ##\lambda_{1}## and ##\lambda_{2}## are small vs. the terms in the unperturbed Hamiltonian but comparable to each other.
Thank you!
If you assume that the system changes like in 1st order perturbation approximation, then you can just do one 1st order calculation with perturbation term ##\lambda_1 V_1## and then do another one for the resulting wave functions with ##\lambda_2 V_2##. You can try applying this process in two different orders, first ##\lambda_1 V_1## and then ##\lambda_2 V_2##, and then the other way around, to estimate how correct this approximation is. If the 1st order PT is really a good approximation, then the order of successive perturbations shouldn't matter.
Another trick is to write
$$\hat{H}_{\text{pert}}=\epsilon (\lambda_1 V_1 + \lambda_2 V_2)$$
and take ##\epsilon## as the "expansion parameter" and do perturbation theory, setting ##\epsilon=1## at the end of the calculation. Effectively, of course, you get an expansion in powers of ##\lambda_1## and ##\lambda_2##.
Thank you for your answers. If I understand correctly, the second method is to use the already established formulas such as the ones given here:
https://en.wikipedia.org/wiki/Pertu...cs)#Second-order_and_higher-order_corrections
e.g.:
$$E_{n}(\epsilon) = E_{n}^{(0)}+\epsilon\langle n^{(0)}|V|n^{(0)}\rangle+\epsilon^{2}\sum_{k\ne n} \frac{|\langle k^{(0)}|V|n^{(0)}\rangle|^{2}}{E_{n}^{(0)}-E_{k}^{(0)}}$$
and use ##\epsilon=1## and ##V=\lambda_{1}V_{1}+\lambda_{2}V_{2}## so that at first order, we just need to add the contributions of each perturbation but at higher order we may get terms proportional to ##\lambda_{1}\lambda_{2}##.
And the first method is also to start with the same equations but using the energies and states corrected by the first perturbation as the unperturbed ones for the second one? And the two methods should at least agree at first order independently of the order in which we apply the perturbations as there cannot be any cross term such as ##\lambda_{1}\lambda_{2}##.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
