Petroleum and Aerospace Engineering DifferenceS
In summary, the conversation discusses the differences between Aerospace and Petroleum engineering in terms of work environment, pay, travel opportunities, degrees required, and job outlook. It also raises questions about whether a bachelor's degree is sufficient or if a master's degree is needed, as well as the availability of research positions in each field.
SpaceDreamer
45
Hi, I am trying to decide between Aerospace and Petroleum engineering an dwas looking for what the differences in the jobs are. Things like work environment, pay, travel, degrees needed, and prospective outlook of each field. Also can a bachelors degree suffice or is a masters needed and are there research positions available for each?
Thank you for your time.
Every one of these things will vary based on the type of job you would like to get within these broad disciplines.
I'd say petrolium engineering would require more travel and field work, but I cannot say for sure, and I bet there are Pet.Engineers who have never seen a site.
FAQ: Petroleum and Aerospace Engineering DifferenceS
What is the main difference between petroleum engineering and aerospace engineering?
Petroleum engineering involves the exploration, extraction, and production of oil and gas resources. Aerospace engineering, on the other hand, focuses on the design, development, and testing of aircraft and spacecraft.
Do petroleum engineers and aerospace engineers use similar skills and knowledge?
While there may be some overlap in certain areas, such as fluid mechanics and materials science, the specific skills and knowledge required for each field are quite different. Petroleum engineers need a strong understanding of geology, drilling techniques, and reservoir engineering, while aerospace engineers must have knowledge of aerodynamics, propulsion systems, and control systems.
Which industry has a higher demand for engineers, petroleum or aerospace?
The demand for engineers in both industries can vary depending on the current economic and political climate. However, in recent years, the demand for aerospace engineers has been higher due to advancements in technology and the growth of the commercial space industry.
Are the job duties and responsibilities of a petroleum engineer and aerospace engineer similar?
While both roles involve problem-solving and using technical skills, the specific job duties and responsibilities can differ significantly. Petroleum engineers may be responsible for designing and implementing oil and gas extraction methods, while aerospace engineers may be involved in designing and testing new aircraft or spacecraft components.
Is there any overlap between the two fields, and can an engineer work in both industries?
There may be some overlap in certain areas, such as using computer-aided design (CAD) software or knowledge of material properties. However, the two fields have distinct differences, and it is unlikely that an engineer would work in both industries simultaneously without additional training or education.
67K
