Pg345's question at Yahoo Answers regarding motion with uniform acceleration
In summary, the object will always have an instantaneous speed equal to the average speed at the midpoint of the interval of time.
MarkFL
MHB
13,288
Here is the question:
Uniformly Accelerating Motion?
Consider an object that accelerates uniformly. If you were to calculate the average speed of the object for a given interval of time, would the object ever be traveling with an instantaneous speed equal to that average speed? If so when? Explain!
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: pg345's question at Yahoo! Answers regading motion with uniform acceleration
Hello pg345,
Let's denote the acceleration of the object as $a$, and use the fact that acceleration is defined as the time rate of change of velocity to write:
\(\displaystyle \frac{dv}{dt}=a\) where \(\displaystyle v(0)=v_0\)
Separating variables and integrating, we find:
\(\displaystyle \int_{v_0}^{v(t)}\,du=a\int_0^t\,dw\)
\(\displaystyle v(t)-v_0=at\)
\(\displaystyle v(t)=at+v_0\)
Now, to find the average velocity on some interval $t_1\le t\le t_2$, we may use:
\(\displaystyle \overline{v(t)}=\frac{1}{t_2-t_1}\int_{t_1}^{t_2}at+v_0\,dt\)
\(\displaystyle \overline{v(t)}=\frac{1}{t_2-t_1}\left[\frac{a}{2}t^2+v_0t \right]_{t_1}^{t_2}\)
\(\displaystyle \overline{v(t)}=\frac{1}{t_2-t_1}\left(\frac{a}{2}t_2^2+v_0t_2-\frac{a}{2}t_1^2-v_0t_1 \right)\)
\(\displaystyle \overline{v(t)}=\frac{1}{t_2-t_1}\left(\frac{a}{2}\left(t_2+t_1 \right)\left(t_2-t_1 \right)+v_0\left(t_2-t_1 \right) \right)\)
\(\displaystyle \overline{v(t)}=a\left(\frac{t_2+t_1}{2} \right)+v_0\)
\(\displaystyle \overline{v(t)}=v\left(\frac{t_1+t_2}{2} \right)\)
So, we see that we will always have the instantaneous velocity equal to the average velocity at the midpoint of the interval.
Perhaps this can be more easily seen geometrically. Consider the following diagram:
We have a right triangle if base $\Delta t$ and altitude $\Delta v$. Its area represents the distance traveled during the time interval $\Delta t$, given the linear velocity function that results from uniform acceleration. Now, we wish to find some value of $h$ such that the rectangle whose base is $\Delta t$ and whose height is $h$, which corresponds to the average velocity, has an area equal to the triangle. Hence:
\(\displaystyle \frac{1}{2}\Delta t\Delta v=\Delta th\)
Divide through by $\Delta t$ and arrange as:
\(\displaystyle h=\frac{1}{2}\Delta v\)
Let \(\displaystyle h=\overline{v(t)}\):
\(\displaystyle \overline{v(t)}=\frac{1}{2}\Delta v=a\frac{\Delta t}{2}=a\frac{t_2-t_1}{2}\)
And so to find the time for which this is true, we may write:
\(\displaystyle t-t_1=\frac{t_2-t_1}{2}\)
\(\displaystyle t=\frac{t_2-t_1}{2}+t_1=\frac{t_1+t_2}{2}\)
FAQ: Pg345's question at Yahoo Answers regarding motion with uniform acceleration
1. What is uniform acceleration?
Uniform acceleration is a type of motion in which an object's velocity changes by the same amount over equal intervals of time. This means that the object is accelerating at a constant rate.
2. How is uniform acceleration calculated?
Uniform acceleration can be calculated using the equation a = (v - u)/t, where a is the acceleration, v is the final velocity, u is the initial velocity, and t is the time interval. This equation is also known as the average acceleration formula.
3. What is the difference between uniform acceleration and constant velocity?
Uniform acceleration refers to a change in velocity over time, while constant velocity means that an object's speed and direction are both constant. In other words, an object with uniform acceleration is always changing its velocity, while an object with constant velocity is not.
4. How is uniform acceleration represented on a graph?
Uniform acceleration is represented by a straight line on a velocity-time graph, where the slope of the line represents the acceleration of the object. On a position-time graph, uniform acceleration would be represented by a curved line that is concave upward.
5. What are some examples of uniform acceleration?
Some examples of uniform acceleration include a car accelerating at a constant rate on a straight road, a ball falling due to gravity, and a rocket launching into space. These examples all involve an object changing its velocity by the same amount over equal intervals of time.
