Phase constant for high pass filter
In summary, the conversation is about finding an expression for the phase constant δ in terms of ω, R and C without using phasors. The suggested method is to replace the label "C" in the diagram with the capacitor's impedance, and then solve for Vout in terms of Vin. The phase is then determined using the formula arctan([imaginary part]/[real part]), taking into account the minus sign attached to δ.
dstdnt
If the input voltage is given by Vin = Vin peak cos ωt, then the output voltage is
Vout = VH*cos(ωt - δ) where VH = Vin peak/(1 + (ωRC)^(−2)) (Assume that the output is connected to a load that draws only an insignificant amount of current.)
Find an expression for the phase constant δ in terms of ω, R and C.
My teacher specifically told us to solve this problem without using phasors, but the only examples in the book of how to solve this kind of problem use phasors. I know that the answer is arctan(-1/(ωRC)), but I have no idea how to derive that!
Hello dstdnt,
Welcome to physics forums!
The way I would do it is, in the diagram, replace the label "C" with the capacitor's impedance. In other words, replace "C" with "1/(jωC)". Then the circuit is just a simple voltage divider. Solve for Vout in terms of Vin.
The phase is arctan([imaginary part]/[real part]). That's almost the same thing as δ. [Notice the problem statement defined Vout = VH*cos(ωt - δ), where there is a minus sign attached to δ. You'll have to take that into account] :wink:
Related to Phase constant for high pass filter
1. What is the phase constant for a high pass filter?
The phase constant for a high pass filter is the angular phase shift between the input and output signals at a specific frequency. It is usually measured in degrees or radians.
2. How is the phase constant calculated for a high pass filter?
The phase constant for a high pass filter can be calculated using the tangent inverse of the ratio between the reactance of the capacitor and the resistance of the circuit. It can also be calculated using the transfer function of the filter.
3. What is the significance of phase constant in a high pass filter?
The phase constant in a high pass filter is important because it determines the frequency response of the filter. It can also affect the time delay and distortion of the output signal.
4. How does the phase constant change with frequency in a high pass filter?
The phase constant in a high pass filter increases with frequency. This means that at higher frequencies, the output signal will be more out of phase with the input signal.
5. Can the phase constant be adjusted in a high pass filter?
Yes, the phase constant can be adjusted in a high pass filter by changing the values of the components in the circuit, such as the capacitance and resistance. This can change the cutoff frequency and the overall frequency response of the filter.
