Phase factor in quantum mechanics
Complex numbers of the form e^{iθ} have an absolute value (modulus) of 1 due to their representation on the unit circle in the complex plane. The norm of a complex number z can be calculated using its complex conjugate z*, leading to the conclusion that the modulus remains constant at 1 regardless of the angle θ. This is derived from the fact that any complex number can be expressed as re^{iθ}, where r is the modulus. The discussion emphasizes that this property is fundamental and elementary in quantum mechanics. Understanding this concept is crucial for grasping the phase factor in quantum mechanics.
Shreya
I watched a lecture in which the professor called the circle expression as a pure phase and took its absolute value to be 1. I don't understand how it's absolute value is 1.
Please refer the image for the circled expression.
Wave function at x,t
Please be kind to help.I would be grateful
Any complex number of the form ##e^{i\theta}## has absolute value (modulus) ##1##.
Can you please explain why is it so?
The norm of a complex number can be calculated using the number ##z## and ##z^*=\bar{z}## the complex conjugate.
So, given ##z=e^{i\theta}, \quad \theta \in \mathbb{R}##, you should be able to compute ##z^*## and its norm.
You will see that the norm is 1 independent on ##\theta##.
Likes Shreya and PeroK
Any complex number can be written ##re^{i\theta}##, where ##r## is the modulus and ##\theta## is the angle in the complex plane. That's fairly elementary, I'm sorry to say!
Thanks a lot 🙏 Pero K and Gaussian97! It helped a lot. 🙂
