Phase invariance of e.m. waves
In summary: So, I believe the invariance applies to physical quantities appearing in formulas that account for a real effect as arguments of e or of trigonometric functions.
bernhard.rothenstein
991
Many textbooks derive the formulas which account for the Doppler shift and for aberration of light from the invariance of the phase of an electromagnetic wave. Do you know an explanation for the invariance?
I would explain it in this way, don't know how much correct it is: if I send n pulses of light or anything else (balls, objects, ecc.), I have to count exactly n pulses of it in every reference frame (I don't know how to call it; "invariance of the number of objects"?); in the same way I will have to count n maximums (for example) of an EM wave in every ref frame; this means that the phase of the EM wave must be invariant. I don't know how to formalize it better.
It's a good question. I have ever thought phase is a very important and deep concept in relativity and QM and so, maybe, it's one of the concepts that could link relativity to QM.
Thanks for your help. Your solution is of help. I put the following question (not statement)
Are the dimensionless combinations of physical quantities which appear at the exponent of e or in the argument of a trigonometric function relativistic invariants?
A wave's propagation vector [itex]\vec k[/itex] (whose magnitude [itex]k[/itex] is the wavenumber [itex]2 \pi / \lambda[/itex]) and frequency together form a four-vector:
[tex]k = (\omega / c, k_x, k_y, k_z)[/tex]
Position and time of course also form a four-vector:
[tex]r = (ct, x, y, z)[/tex]
Therefore their four-vector "dot product" is a Lorentz invariant:
[tex]k \cdot r = \omega t - k_x x - k_y y - k_z z = \omega t - \vec k \cdot \vec r[/tex]
I would say no. For example
[tex]e^{i\omega t}[/tex] is not invariant, while
[tex]e^{i(\vec k \cdot \vec r - \omega t)}[/tex] is invariant.
I think a good question would be, why is the wave vector a four-vector? I think it inherents from the wave equation (the Fourier transformed wave equation).
phase invariance
I rephrase my question
Are the combinations of physical quantities that appear in formulas that account for a real effect as arguments of e or of trigonometric functions relativistic invariants?
Example
radiactive decay exp(-t/T)
Plancks distribution law exp(-hf/kT)
and the phase of the e.m. wave in discussion.
Does your counter example account for something that hapens in nature?
Regards
The first paragraph on page 2 of arXiv:0801.3149v1 reads:
" If the plane-wave disturbance in Eq. (1) is observed
from a different reference frame, the phase of the wave
should remain invariant quantity. This claim is clarified
by the fact that the elapsed phase of the wave is proportional
to the number of wavecrests that have passed the
observer, and thus it must be frame-independent, and
hence, a Lorentz scalar. Alternatively, the same
conclusion follows by considering optical interference experiments
from different inertial frames, where the phase
is the quantity that determines the interference pattern."
Example
Regards
A relatistic invariant must be a four-scalar.
t and f are neither in any expression.
The arguments of trig frunctions and exponentials must be dimensionless,
which is not the same as invariant.
FAQ: Phase invariance of e.m. waves
What is phase invariance of electromagnetic waves?
Phase invariance refers to the property of electromagnetic waves where their amplitude and frequency remain constant, but their phase (the position of the wave in its cycle) can change without affecting their overall properties.
Why is phase invariance important in the study of electromagnetic waves?
Phase invariance is important because it allows us to manipulate the phase of electromagnetic waves without altering their fundamental properties. This is useful in applications such as signal processing and telecommunications.
How is phase invariance related to the concept of superposition?
Phase invariance is closely related to the concept of superposition, which states that when two or more waves overlap, the resulting wave is the sum of the individual waves. Since phase invariance allows for the manipulation of wave phases, it also affects how these waves combine and interfere with each other.
Can phase invariance be observed in everyday life?
Yes, phase invariance can be observed in everyday life through various phenomena such as interference patterns in water waves or sound waves. It is also utilized in technologies such as radio and television broadcasting.
Are there any limitations to phase invariance?
While phase invariance is a fundamental property of electromagnetic waves, it is not absolute. It can be affected by external factors such as interactions with matter and gravitational fields, which can alter the phase of the wave. Additionally, in certain situations, phase invariance may not hold for certain types of electromagnetic waves, such as those with non-linear properties.
