Phase shift and amplitude change when put through FIR filter
In summary, the conversation discusses a problem involving a sinusoidal signal, an FIR filter, and finding the factor and phase shift of the input signal. The conversation also mentions a theory involving z and the normalized frequency, which is equal to omega divided by the sampling rate. The solution can be obtained directly from H(z).
Jd303
35
Hey all,
I am having trouble with this problem:
A sampled sinusoidal signal having a normalized frequency of 0.30π is sent through an FIR filter. The filter impulse response is,
h[n] = 1/3δ[n] + 1/3δ[n-1] + 1/3δ[n-2]
From this I must find out by what factor the input signal is multiplied by and what the phase shift is, (if there is in fact a phase shift).
my current theory is:
Let z = e^(jω) (j = i for those not in an electrical field)
H(z) = 1/3 + 1/3*z^(n-1) + 1/3*z^(n-2)
y[n] = H(z)*z^n
Then I am lost from here assuming my above theory is even correct. Any help would be greatly appreciated as I have been stuck on this one for a while. :)
Do you know what "normalized frequency" means? I sure don't. It must be related to the sample time T. So assuming T = 1 then f = 0.3pi/T?
Not to worry, figured it out you can obtain phase and magnitude directly from H(z), also normalised frequency is just omega divided by the sampling rate
FAQ: Phase shift and amplitude change when put through FIR filter
What is a phase shift?
A phase shift is a change in the timing or position of a signal. In the context of an FIR filter, it refers to the delay or advance of the output signal compared to the input signal.
How does a phase shift affect a signal?
A phase shift can cause changes in the frequency and amplitude of a signal. It can also affect the overall shape and timing of the signal.
What causes a phase shift in an FIR filter?
A phase shift in an FIR filter is caused by the delay elements within the filter, as well as the coefficients used to weight the delayed signals.
What is amplitude change in an FIR filter?
Amplitude change refers to the change in the magnitude or strength of a signal after passing through an FIR filter. It can be affected by the filter coefficients and the characteristics of the input signal.
How can I control the phase shift and amplitude change of an FIR filter?
The phase shift and amplitude change of an FIR filter can be controlled by adjusting the filter coefficients and the filter order. Different filter designs and techniques can also be used to achieve specific phase and amplitude responses.
10K
