Phase space and the quantum Liouville theorem
In summary, the conversation discusses the concept of phase space in relation to the quantum Liouville theorem. The quantum analog of the distribution function on the classical phase space is the Wigner distribution function, which satisfies the quantum version of the Liouville equation. However, in quantum mechanics, the variables x and p are turned into operators, leading to a non-commutative geometry that does not allow for points in phase space to be defined in the same way as in classical mechanics. This results in a different understanding of the spacing and interpretation of points in phase space.
skynelson
58
I would like to understand phase space better, spec. in relation to the quantum Liouville theorem. Can anyone point me to a decent online resource? I am most interested in conceptual understanding to begin with.
Liouville's theorem says that if you follow a point in phase space, the number of points surrounding that point will always be the same. Or, equivalently, "The distribution function is constant along any trajectory in phase space."
In the case of a quantum density matrix, what does the phase space represent? The various possible states and their probabilities?
What, then, is an intuitive interpretation of the "points in phase space", and their "spacing"?
The quantum analog of the distribution function on the classical phase space is called the Wigner distribution function. It's basically a Fourier transform-like representaton of the density matrix. It reduces to the classical distribution function you mentioned in the classical limit. But unlike the classical counterpart the Wigner distribution can take on negative values as well.
The "equation of motion" this object satisfies is the quantum version of the Liouville equation.
You cannot really talk about a point in phase space in the quantum sense. The phase space is classically spanned by coordinates x and momentum p. But in quantum mechanics these variables are turned into operators. The fundamental reason for this is the assumption of non-commutativity: [x,p] = ih. This relation can only be satisfied by assuming the variables are now operators.
But a more important consequence is that we cannot think of x and p as spanning an ordinary phase space. The reason is that the non-commutative property does not allow us to simultaneously specify both momentum and coordinate with infinite precision. That means we cannot talk about coordinates of a space in the usual sense. Rather, we are dealing with what is called a non-commutative geometry: a space in which coordinates in different directions fail to commute. This goes beyond my knowledge though, but it should be clear that the picture of an ordinary phase space breaks down because of this. It is replaced by quantum states and density matrices.
FAQ: Phase space and the quantum Liouville theorem
What is phase space in physics?
Phase space in physics is a mathematical concept that describes the possible states of a physical system. It is a multi-dimensional space where each point represents a unique set of values for all of the system's variables, such as position, momentum, and energy.
How is phase space related to the quantum Liouville theorem?
The quantum Liouville theorem is a fundamental principle in quantum mechanics that describes the evolution of a system's state in phase space. It states that the volume of phase space occupied by the system will remain constant over time, unless acted upon by an external force or measurement.
3. What is the significance of the quantum Liouville theorem?
The quantum Liouville theorem is significant because it provides a way to predict the behavior of a quantum system over time. It allows scientists to calculate the probability of a system being in a particular state at a given time, which is essential for understanding and manipulating quantum systems.
4. Can the quantum Liouville theorem be applied to all quantum systems?
Yes, the quantum Liouville theorem can be applied to all quantum systems, regardless of their complexity. However, it is most commonly used in systems with a large number of particles, such as in statistical mechanics, where it helps to describe the behavior of gases and fluids.
5. How does the quantum Liouville theorem differ from the classical Liouville theorem?
The quantum Liouville theorem differs from the classical Liouville theorem in that it takes into account the probabilistic nature of quantum systems. In classical mechanics, the evolution of a system's state in phase space is deterministic, while in quantum mechanics, it is described by a wave function that represents the probability of finding the system in a particular state. Therefore, the quantum Liouville theorem is essential for understanding the behavior of quantum systems, while the classical Liouville theorem is more applicable to classical systems.
