I Phase Speed of Wave in non-relativistic Doppler Shift Derivation
In the discussion, the relationship between the frequency and wavelength of sound waves is examined, particularly in the context of a moving siren and a stationary observer. The derived formula for the observed frequency, accounting for the Doppler effect, shows that the frequency measured by the observer is affected by the speed of the source relative to the medium. The question arises about why the wavelength at the source, ##\lambda_0##, equals ##\frac{v_w}{f_0}##, despite expectations from Galilean transformation. The resolution lies in recognizing that both the observer and the emitter are at rest relative to the air, leading to the same wave speed measurement. This understanding clarifies the consistency in wave speed across different reference frames in this scenario.
unified
TL;DR Summary
The phase speed of a wave in the derivation of the non-relativistic Doppler shift does not change between reference frames. Shouldn't the Galilean transformation apply?
Consider the situation where an observer at rest on the ground measures the frequency of a siren which is moving away from the observer at speed ##v_{Ex}##. Let ##v_w## be the speed of the sound wave. Let ##\lambda_0##, ##f_0##, ##\lambda_D##, and ##f_D## be the wavelengths and frequencies measured by the emitter and ground observer. Let T be the wave's period measured by the ground observer. Following the standard non-relativistic doppler shift derivation, ##f_D## = ##\frac{v_w}{\lambda_D}## = ##\frac{v_w}{\lambda_0 + v_{Ex}T}## = ##\frac{v_w}{\frac{v_w}{f_0} + \frac{v_{Ex}}{f_0}}## = ##\frac{f_0}{1 + \frac{v_{Ex}}{v_w}}##.
My question, is why is ##\lambda_0## = ##\frac{v_w}{f_0}##? If the wave speed on the ground is ##v_w##, shouldn't the wave speed as measured by the emitter be calculated using the Galilean transformation? Instead it is the same value as measured by the ground observer.
To answer my own question, we are comparing the frequency measured by the ground observer -- who is at rest relative to the medium air -- with that measured by an observer moving with the siren and at rest relative to the air. Since they are both at rest relative to the air, they will measure the sound to have the same speed ##v_w##.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
