crick
- 43
- 4
I'm a Physics student currently ending the bachelor degree. Since I study in Europe (Italy) there are quite big differences in the degrees system between Europe, UK and USA.
Start from the assumption that I would like in the future to do a PhD in the UK or in USA.
My main question is: do a MSc in Italy or in Europe (2 years, 120 ECTS) represent a "waste of time"* for the road to a PhD in UK or USA or is it, in some way, an advantage?
*With "waste of time" I refer to the situation in which, at the time for admission to PhD (in UK or USA), I will considered the same way as someone who holds a bachelor (from the country at issue), even if I have a BSc, plus a MSc, or even in a worse way because I come from a foreign european university.
I'll explain better, starting from USA.
In USA students (correct me if I'm wrong) after the Bachelor in Physics (4 years) enroll for Graduate Programmes (Master and/or PhD). In the case of Physics I see that a lot of University put Master and PhD togheter in a single "graduate programme".
So, supposing that I want to do a PhD in USA, should I avoid the european MSc and directly go for the "graduate programme" after the (european) BSc? (In that case doing a MSc would be a "waste of time")
But someone says that this is not possible because in Europe students do a three years BSc, which is considered in USA less than a Bachelor (because it's 4 years there), so
$$\mathrm{European \,\, BSc \, (3 \, years) \, < \, American \, \, Bachelor \, (4 \, years) \,}$$
If this is true, if I do the european MSc, then can I enroll for the PhD in USA, without the Master?
$$\mathrm{European \,\, BSc \, (3 \, years) \,+\, European \,\, MSc \, (2 \, years) \, \approx \, American \, \, Bachelor\, (4 \, years) \,+ Master}$$
Or will I be considered in the same way as an american bachelor?
$$\mathrm{European \,\, BSc \, (3 \, years) \,+\, European \,\, MSc \, (2 \, years) \, \approx \, American \, \, Bachelor\, (4 \, years)}$$
For UK is it true that with a UK BSc (3 years) one can go directly to a PhD (which looks quite strange)?
If this is true, then, as for USA, do I lose my time (again, supposing that I would like to do a PhD), in doing a 2 two year MSc in Europe? Should I try to go directly into a PhD in UK after BSc?
On the contrary, if I do a MSc in Europe, then is this considered in the same way as the MSc offered in the UK (which are even shorter, only 90 ECTS)? So can I go to PhD in UK with a MSc from Europe ?
So if my dream is to do a PhD in UK or USA what should I do if I have a european BSc? The options are
- Do a MSc in Europe and then apply for PhD
- For USA: go directly into Graduate Programme (if possible)
- For UK: go direclty to PhD (if possible) or get a MSc in UK which is shorter than MSc in Europe
- avoid to waste time (in the sense specified above)
- take the path that gives the best opportunities in terms of admission to PhD prgramme*
