Phone coming back to life after being exposed to saltwater
  • Thread starter Thread starter greypilgrim
A phone exposed to saltwater can exhibit temporary functionality issues, as experienced when it initially turned off but later powered back on. The device may face problems like not recognizing SIM cards, yet can return to full functionality after drying out. Water exposure can lead to corrosion, which poses a risk of future failure due to the formation of conductive salts. Immediate removal of the battery and proper drying are crucial to prolonging the device's life. Users are advised to back up data and consider professional cleaning or replacement soon.
greypilgrim
Hi.
I went swimming with my phone (turned on) in one of those waterproof pouches. After a while, I noticed a bit of water inside, went to the shore, took it out and dried it. It still seemed to be working, but not for long: it turned off. What happened next:
  1. First it would not turn on at all.
  2. Then it would only go to the (Huawei) splash screen.
  3. About 15 min later, it would turn on and be fully functional.
  4. The next morning, it would not see any of the two SIM cards anymore, but everything else worked.
  5. The next day it was fully functional again, and has remained so for the last four days.
So what happened here? The water doesn't seem to have caused permanent damage (yet). Are functions turned off if the circuit detects that something is wrong?
I'll probably still have to expect the phone to break at some point due to corrosion...
In electronics, corrosion caused by water is a difficult beast. If the primary dose hit some working electronics, then it'll turn some metals into salts and oxides, and these are often hygroscopic => even if the first dose dried out (and so the electronics could be turned on) it'll draw in new water from the air and depending on luck and moisture level it'll produce some kind of 'am I in the mood to to work today?' spirit.
If the battery was not removed immediately (and, even worse: it was kept working) before drying out completely (and that may take days, in a very dry, and possibly: warm environment), then likely it won't last long.
The internal protection (if any) failed yet survived without the usual drying-out-in-a-bag-of-rice trick. Amazing. I had this happen to an iPod that fell in a pool, then years later got it to work. The conductive salts with moisture can induce all sorts of fault conditions and yet be relatively high impedance if perfectly dry and not rusted (oxide)
Plan on backing up, get a pro cleanup or trading it in real soon.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
