- 32,820
- 4,717
Animated GIF
And now for something completely different...
It GIF files first started out, they were just image files. But now, depending on the viewing app or browser, these files have the ability to show short animated image. So for this contest, for the first time, it will be on animated GIF images.
Since this is our first contest of this type, there is no theme or subject for you to conform to. Any animated GIF images is acceptable, within the general rules of the contest and PF Guidelines. For this contest, you are allowed to modify size and to crop the images if necessary. Your GIF images may come from still images, or videos, but the restriction that the images or videos were taken BY YOU still holds.
Please be mindful that animated GIF file size can be quite big. Your moving images should be less than 3 seconds, but you may have it play in a continuous loop. Do a lot of cropping and reducing image size so that your animated GIF file size does not tax the PF storage too much.
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Contest Rules:
Zz.
