Photo Contest - Magnetism (3/2-3/8)
In summary, the conversation revolved around the topic of the new project proposal. The team discussed the main objectives and the timeline for completion. They also addressed potential challenges and assigned tasks to each member. Overall, the team is excited about the project and confident in their abilities to successfully execute it.
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
32,820
4,717
Magnetism
Hey, after all, this IS the Physics Forums! :-p
This week, the main subject of your photo must show something that has a magnetic field, or with the designed purpose of producing a magnetic field. So a permanent magnet or a solenoid will qualify. A clear depiction of a MRI facility also qualifies. A power generating turbine? Why not? A dynamo? Even better!
Please make sure that the subject can easily be recognized as having a magnetic field or is designed to produce a magnetic field.
Contest Rules:
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Likes berkeman, AlexCaledin and davenn
One of the four loudspeakers in a dusty, old, Fender Super Reverb tube guitar amplifier:
Likes Klystron, morrobay, jim hardy and 4 others
Likes Klystron, morrobay, AlexCaledin and 2 others
From an unstable voltage stabiliser lying in my house, waiting for my surgery:
Likes morrobay, jim hardy, AlexCaledin and 1 other person
Ask and ye shall receive...
Old Dynamo
It's at the hydro power plant in Georgetown Colorado
nameplate says
Crocker-Wheeler Electric Co
Ampere NJ USA
Pat'd May 5, 1891
3 H.P. Size 3 C No. 817
R.P.M. 975 Volts 230 Amps 12
have photo of nameplate if anyone is curious
old jim
Likes Klystron, davenn, morrobay and 5 others
Weird, with each new post I feel more attracted to this thread.
Likes OmCheeto, davenn, AlexCaledin and 2 others
... a "Man of Steel" ?
Likes Klystron, OmCheeto, DennisN and 3 others
Repulsive force between two face polarized circular magnets
Likes Klystron, davenn, kuruman and 1 other person
Are you sure it's repulsive and not attractive? :smile:
Likes AlexCaledin
The attractive part cannot be seen!
Likes Klystron and AlexCaledin
Precisely my point!
Likes Klystron, berkeman, phinds and 6 others
Likes Wrichik Basu and DennisN
Borek said:
A very nice photo! I see many poles on a photo taken by a Pole. A monopole?
Likes berkeman and Borek
Final day to submit your photo for this contest.
Zz.
Windings of a quadrupole magnet for electron beam focusing.
Zz.
Likes Klystron, morrobay, BillTre and 2 others
That's an interesting one
comparing to old fashioned TV deflection yokes
and thinking of Right Hand Rule
i can't quite envision the field at center
sum of the external fields from the four solenoids i'd surmise ?
Aha! perhaps the focus coil is that brass ring shaped structure behind the four flat coils ? It would produce an axial B field...
Thought provoking apparatus there, ZZ !
Likes berkeman
Maybe it's a bit like this?
Likes jim hardy
I somehow knew that there would be questions about this when I posted it.
I didn't show the entire "magnet" complex. There is a set of quadrupole magnets not shown here, and I mischaracterized the one shown. This is the last magnet in the entire complex, and it is actually a steering magnet.
The brass "ring" is an ICT to measure the charge in each bunch going through the beam pipe.
Zz.
Likes Wrichik Basu and jim hardy
ICT ? Some form of Current Transformer ?
That makes sense - Thank You !
Aha Found it
Integrating Current Transformer
http://accelconf.web.cern.ch/AccelConf/IBIC2014/papers/wepf06.
seems a cousin to Rogowski Coil
Love the variety of hings i learn about here !
Likes Klystron and Wrichik Basu
MR fluid in a magnetic field.
Likes AlexCaledin, jtbell, jim hardy and 3 others
Useful magnetic mouse.
ic
Likes AlexCaledin and DennisN
The home made AM radio transmitter I designed to create magnetic field covering the whole apartment, received by any radio with the "middle wave" band. The frequency is 615 kHz, as marked on the bulb-like quartz resonator. The big chocolate colored capacitor (10 nF) is tuning the wire loop to that frequency.
Likes Klystron, morrobay, Wrichik Basu and 1 other person
epenguin said:
Useful magnetic mouse.View attachment 239965 ic
Once again, your photo exceeds the size limit of our contest, and will not be included in the poll.
Zz.
Zz.
:blushing: Sorry, it looked just like the others on my screen but now I am seeing when I click on it it enlarges and the others don't. I will have to return to the external hosting system since the seemingly convenient PF upload does this. (Unless there is some trick I am missing.)
I copy them into Paint
then use paint's "Resize" button . It shows you height and width in either % or actual pixels.
When it'll fit i save as (name)_Resized.jpg and upload that copy.
old jm
Likes Borg
old jm
Well thank you. Firstly is this okay now? It is now smaller than the others. That was not intentional.
My computer skills level is lower basement. I thought Paint?? I seemed to have heard the word before.
The nearest thing I could find to it was this https://www.macworld.co.uk/how-to/mac-software/resize-images-mac-3689216/#toc-3689216-1
  1. Locate the image (either using the Finder, or on your Desktop).
  2. Double click on the image - this should open the image in Preview, if it doesn’t, close it and right click to choose Open With and select Preview.
  3. Click on Tools.
You never remember everything you did, but basically most of those things did not work, the finder didn't find, double-clicks and right clicks did nothing and I looked like losing my whole photo library on the way but apart from that small inconvenience :oldeek: :oldsmile: ... somehow or other I got the image into Preview tools I think somehow. Don't think I could control the size of the picture but I could give the number of pixels, the required 800X600. However I have no way of checking this has worked, Info on the picture does not tell me Pixels.
I think I must return to my hosting by tinypic, it is simple to use and worked in the past. Only trouble with it is I think they delete your stuff if you don't go there for a month so sooner or later I will lose everything there; other hosting sites I have dabbled with are complicated hassle to learn, and I'm sure soon as I did it I would get the hated upgrade and I wouldn't be able to work it any more. Please excuse Luddite Guttenberger rant.
Yep i have to log into photobucket periodically as well. They're increasing the pressure to buy a subscription .
OOPS MSPaint that comes with Windows is what i use. It's primitive but then so am i..
Glad to learn I'm not alone in that self assessment...
i simply 'copied your image to clipboard' (Windows terms) then pasted it into MSPaint
then clicked on Paint menu "Resize" and selected "Pixels"
and here's what it showed me.
I have no idea if it's 716 by 600 on your computer, or in PF's copy for that matter
but that's how i prepare pictures when they must be of certain size in pixels..
Surely MAC has something analogous to Microsoft's Paint.
Good Luck !
old jim
  • #31
For what it's worth : I take photo with phone and send to my email. Then on a standard internet computer from inboxed photo I download photo and upload to reply page here.
  • #32
On our PC, we have installed IrfanView. It offers more functionality than MS paint, and is easy to use as well.
@epenguin You can try out www.picresize.com for photo compression. I often use it from my phone, since I don't have a photo editor app. The site offers basic photo compression and resizing functionality, and works well.
Likes jim hardy
Related to Photo Contest - Magnetism (3/2-3/8)
1. What is the theme of the photo contest?
The theme of the photo contest is magnetism. This means that the photos submitted should capture the concept of magnetism in some way.
2. Can I submit more than one photo?
Yes, you can submit up to three photos for the photo contest. However, please make sure that each photo is unique and meets the theme of the contest.
3. Is there a specific format or size requirement for the photos?
There is no specific format or size requirement for the photos. However, we recommend submitting high-quality photos in a standard image format (e.g. JPEG, PNG) for the best chance of winning.
4. Who can participate in the photo contest?
The photo contest is open to everyone, regardless of age, location, or profession. We encourage anyone with an interest in photography and magnetism to participate!
5. How will the winners be selected?
The winners will be selected by a panel of judges based on the creativity, originality, and relevance to the theme of magnetism. The decision of the judges will be final.
  • General Discussion
