- 32,820
- 4,718
Simple Harmonic Motion
A few weeks ago, we inaugurated the use of animated GIF as part of our contest theme. It went quite well, so I'm bringing it back again. This time, we have a specific theme for your animated GIF. Your photo must show something that moves back and forth repeatedly, just like a simple harmonic motion.
Your animated GIF does not have to show a substantial time cycle. One or two cycles should be sufficient, unless you think that more cycles will make it convincing that your subject is undergoing this repeated motion.
As always, please be mindful of the size of your animated GIF file if you are uploading it to PF.
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Contest Rules:
Zz.
