- 32,820
- 4,718
The Elements
For this contest, your photo must have, as its main subject, something that is made up of, or popularly identified with, a single element.
For example, your gold jewelry, even though it may contain a small amount of other elements, is identified usually as a single element of gold, i.e. Au. A lot of cookware are made of aluminum (with added impurities), and so it can be identified as the element aluminum, or Al.
However, you can't use things such as the regular table salt, since it has equal portions of Na and Cl, and it is a compound, not an element. The same with water since H2O is a compound.
Good luck!
Zz.
Contest Rules:
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Good luck!
Zz.
Contest Rules:
Zz.
