- 32,820
- 4,718
Waterworld
The requirement for this contest is not as simple as at first glance, so you should pay a bit more attention.
The theme is on water, but it must be ALL water. Your photo must show water over the entire photo, not just over a majority of it. Every square inch (or mm) of your photo must show water.
So a photo taken underwater qualifies. A photo of a water surface and nothing else in the photo also qualifies. A photo of water taken through a clear, transparent glass also qualifies as long as the glass medium is not apparent.
The only exception being made here will be the inclusion of objects that are in the water. So fish, rocks, etc. that are in the water are allowed. Thus, a photo of the inside of a fish tank qualifies IF it does not show the outline of the tank itself. A photo of water in the pool showing the bottom of the pool (and maybe coins resting at the bottom of the pool) also qualifies.
So show us your water world!
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Contest Rules:
Zz.
