- 32,820
- 4,718
You Light Up My Life
While the object of that Debbie Boone song was a person, the object in this contest is a source, or sources of visible light. Your photo must show a light source/s, and it/they must be emitting light. A lamp, a light bulb, a candle, LED's, etc. qualify. A moon does not, since it is not a light source, but a light reflector.
Please note that the source must be lit in the photo, and we can clearly see light being given off by the source.
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Contest Rules:
Zz.
