Photoelectric effect: a recreative quiz
In summary, the conversation discusses the photoelectric effect, specifically in relation to a photon with an energy of 2.25 eV causing a photoelectron to be ejected from a potassium target with a maximum energy of 0.50 eV. This indicates that the photoelectric threshold of potassium is 1.75 eV. The conversation then delves into the momentum of the photon and photoelectron, noting that the target ions are necessary to take up the recoil momentum. The quiz then questions what happened to the momentum conservation law, with one participant suggesting that it is not necessary to reference the internal structure of the target.
lalbatros
1,256
Let us consider the photoelectric effect described on http://hyperphysics.phy-astr.gsu.edu/hbase/mod1.html/" .
A photon has an energy of 2.25 eV and produces a photoelectron effect on a potassium target,
the maximum energy of the photoelectron is 0.50 eV,
indicating the photoelectric threshold of potassium is 1.75 eV.
Calculating the momentum of the photon and phtoelectron gives:
momentum photon = 1.2E-27 N.s
momentum electron = 270E-27 N.s
The quiz is: what happened to the momentum conservation law?
Michel
A photon has an energy of 2.25 eV,
a photoelectron is ejected from a potassium with the maximum energy of 0.50 eV,
Michel
Nothing.
1. Photoemission theory has shown that the photon does not impart any significant transverse (in plane parallel to the surface) momentum to the photoelectron. The predominant origin of the transverse momentum is due to the transverse momentum of the electron while it is in the solid.
2. The photoelectron momentum in the perpendicular direction is due to a combination of (i) the momentum of the photon and (ii)the momentum of the electron while it is in the solid before it was liberated.
3. The lattice ions are necessary for the photoemission process because they take up the recoil momentum. This means that you cannot get the standard photoemission process from a free electron gas.
Zz.
Too bad to ask such a quiz in an expert forum !
I should have tried an homework forum !
However, I think it is not necessary to make any reference to the internal structure of the target.
It is enough to recognize that the target plate can take off a recoil momentum and close the balance.
But your explanation is more physical !
Michel
FAQ: Photoelectric effect: a recreative quiz
1. What is the photoelectric effect?
The photoelectric effect is the phenomenon in which electrons are emitted from a material when it is exposed to light or other forms of electromagnetic radiation. This effect was first observed by Heinrich Hertz in 1887 and was later explained by Albert Einstein in 1905.
2. What is the significance of the photoelectric effect?
The photoelectric effect is significant because it provided evidence for the particle nature of light and contributed to the development of quantum mechanics. It also has important practical applications, such as in photovoltaic cells used for solar energy and in photoelectric sensors.
3. How does the photoelectric effect work?
The photoelectric effect occurs when photons (particles of light) strike the surface of a material, causing electrons in the material to be ejected. The energy of the photons must be greater than the material's work function (the minimum amount of energy required for an electron to be released) for this effect to occur.
4. What factors affect the photoelectric effect?
The photoelectric effect is influenced by several factors, including the intensity and frequency of the incident light, the properties of the material (such as its work function and conductivity), and the distance between the material and the light source.
5. What are some real-world applications of the photoelectric effect?
The photoelectric effect has numerous practical applications, including in solar panels for generating electricity, in camera sensors for capturing images, in photocells for detecting light, and in photomultiplier tubes for detecting very low levels of light. It is also used in spectroscopy to analyze the composition of materials and in electron microscopy to produce high-resolution images.
