Photoelectric effect and work functions
In summary, the work functions of two metals increase when the threshold wavelength in the photoelectric effect increases. The relationship between frequency and wavelength is important in understanding this phenomenon. The threshold wavelength is inversely proportional to the work function and is determined by the type of metal. In the critical case, the work function is related to the wavelength by the equation \phi = \frac{hc}{\lambda}. If the photon energy exceeds the work function, the excess energy is converted into kinetic energy of the electron.
bullroar_86
30
what can be said about the work functions of two metals when the threshold wavelength in the photelectric effect increases.
I'm having trouble finding and equation to describe this relationship.
ANyone have any ideas?
Well, the work function, [itex]\phi = hf_{0}[/itex], where [itex]f_{0}[/itex] is the threshold frequency. Do you know the relationship between frequency and wavelength?
Threshold wavelength is inversely proportional to the work function of the metal .
Of course the threshold wavelength is decided by the metal itself.
For the critical case the work function is [itex]\phi[/itex] is related to the wavelength as:
[itex] \phi [/itex][itex]= \frac{hc}{ \lamda }[/itex]
You spelt lambda wrong, that's why it won't come out.
If the photon energy exceeds the work function, the excess energy appears as the kinetic energy of the electron.
Related to Photoelectric effect and work functions
1. What is the photoelectric effect?
The photoelectric effect is the phenomenon where electrons are emitted from a material when it is exposed to electromagnetic radiation, such as light. This effect was first observed by Heinrich Hertz in 1887 and was later explained by Albert Einstein in 1905 through his theory of photons.
2. What is the work function?
The work function is the minimum amount of energy required to remove an electron from the surface of a material. It is also known as the binding energy or ionization energy. The work function varies depending on the type of material and can be measured in electron volts (eV).
3. How does the work function relate to the photoelectric effect?
The work function is directly related to the photoelectric effect as it determines the minimum energy required for an electron to be emitted from a material. If the energy of the incident light is greater than the work function, electrons will be emitted from the material. If the energy is less than the work function, no electrons will be emitted.
4. What is the threshold frequency in the photoelectric effect?
The threshold frequency is the minimum frequency of incident light required to cause the photoelectric effect. It is directly related to the work function, as the threshold frequency is equal to the work function divided by Planck's constant. Any frequency of light below the threshold frequency will not cause the emission of electrons.
5. How is the photoelectric effect used in everyday life?
The photoelectric effect has many practical applications in everyday life. Some examples include solar panels, which convert light energy into electrical energy, and photocells, which are used in automatic lighting systems. The photoelectric effect is also used in photography, photocopying, and digital imaging technologies.
  • Quantum Physics
