hurricane89
- 19
does increasing the intensity of the light lower the threshold frequency at which photons knock off electrons?
The work function is a function of temperature right? Of course I'm nitpicking a little bit but I'm interested :) Of course the material will have to absorb that wavelength.
The photoelectric effect is a phenomenon where electrons are emitted from a metal surface when it is exposed to light. This was first observed by Heinrich Hertz in 1887 and was later explained by Albert Einstein in 1905 through his theory of quantum mechanics.
The photoelectric effect has many practical uses in various fields such as solar cells, photodiodes, photoelectric sensors, and photomultiplier tubes. It is also used in photography, spectroscopy, and in the development of electronic devices.
The photoelectric effect refers to the emission of electrons from a metal surface, while the photovoltaic effect is the conversion of light energy into electrical energy in a semiconductor material. The photoelectric effect is used in devices such as photomultiplier tubes, while the photovoltaic effect is the basis for solar cells.
The photoelectric effect is influenced by several factors such as the intensity of light, the frequency of light, the type of metal used, and the surface area of the metal. Higher intensity and frequency of light, as well as a larger surface area of the metal, will result in a higher number of emitted electrons.
The photoelectric effect provides evidence for the particle nature of light, as described in Einstein's theory of quantum mechanics. The fact that electrons are emitted only when light of a certain frequency is shone on a metal surface supports the idea that light is made up of discrete particles, or photons, with specific energies.
