Photoelectric effect (questions)
In summary, the conversation discusses the behavior of metal when exposed to sunlight and the loss of electrons. The speaker clarifies that in the case of solar panels, electrons are promoted from the valence to conduction band, while for the photoelectric effect, the work function increases as more electrons are liberated. The speaker also mentions that electrons from the environment will quickly repopulate the metal atoms that lost them, and this process is common for all materials. There is no specific lifetime limit for solar panels converting light to energy, and high energy gamma rays can strip the atoms of every electron in every electron shell. However, the metal will still maintain its appearance and properties as it quickly regains electrons from the environment.
Dav333
91
hi, Just had a few questions on the topic.
With say a sheet of metal exposed to sun light, what happens when all the electrons are gone? Is it still a sheet of metal? Just without the negative charge? will it look any different?
And how long until all electrons are gone? Is there a life time limit for solar panels converting light to energy?
Thanks in Advance.
Assuming that the metal is isolated, that is, not part of an electric circuit...
When you knock some (negatively charged) electrons off, the metal becomes positively charged, right? What does that positive charge do when you try to knock more (negatively charged) electrons off?
I'm not sure, but I think you are confusing the photelectric effect and how photovoltaics work. Solar cells don't have free electrons shooting off a surface; electrons are promoted from the valence to conduction band, where they participate in a closed circuit of current. As electrons leave the device, new ones are brought in (becasue the circuit is closed).
For the photoelectric effect, as electrons are liberated, the work function must increase- it becomes more difficult to liberate additional electrons.
thanks for the help.
So after a while no more electrons will be free on the piece of metal?
What about high energy gamma rays. Can they strip the atoms of every electron in every electron shell?
Then would it still look & be a piece of metal?
thanks.
Electrons from the environment would be quickly attracted to the metal and repopulate the atoms that earlier lost them. It is a common thing for materials to lose electrons and then get some back again. All of your experiences with static electricity, like clingy clothes coming out of the drier, or if you rub a balloon on your sweater and them it will stick to the wall, in such cases friction has scraped electrons off of atoms. When the stickiness goes away that means the population of electrons has gone back to normal. It will go back to normal faster for a metal than for other materials. Going back to the neutral condition is slowest for insulators.
FAQ: Photoelectric effect (questions)
1. What is the photoelectric effect?
The photoelectric effect is a phenomenon in which electrons are emitted from a material when it is exposed to electromagnetic radiation, such as light.
2. Who discovered the photoelectric effect?
The photoelectric effect was discovered by physicist Albert Einstein in 1905.
3. What is the significance of the photoelectric effect?
The photoelectric effect provided evidence for the particle nature of light and helped to establish the concept of photons. It also led to the development of technologies such as photovoltaic cells and photoelectric sensors.
4. How does the photoelectric effect work?
When a material is exposed to electromagnetic radiation, the photons (particles of light) transfer their energy to the electrons in the material. If the energy of the photons is high enough, the electrons can overcome the binding energy of the material and be emitted as photoelectrons.
5. What factors affect the photoelectric effect?
The intensity and frequency of the incident light, as well as the properties of the material (such as work function and thickness), can affect the photoelectric effect. Increasing the intensity of the light or using higher frequency light can increase the number of photoelectrons emitted, while increasing the work function or thickness can decrease the number of photoelectrons.
