Photoelectric effect , Superposition of sine waves
In summary: Therefore the average number of photons per second for the compound wave is ##\frac{5}{4}n_p##, which then gives ##\frac{5}{4}I_s## for the current.In summary, the photoelectric effect experiment involves a monochromatic plane wave of light falling on a metal plate, with an electric field that varies according to E=E_0 \cos (\omega t). This results in a saturation current of 6 μA. If the light wave is instead governed by E=E_0 (1+\cos (\omega t)) \cos (\omega t), the saturation current will be 6.75 μA. This is because the average intensity for the two waves has the same proportionality
Terry Bing
48
In a photoelectric effect experiment, a monochromatic plane wave of light falls on a metal plate. The electric field in the light wave at a point near the plate varies according to [itex]E=E_0 \cos (\omega t)[/itex]. This results in a saturation current of 6 μA. If instead, the light wave was governed by [itex]E=E_0 (1+\cos (\omega t)) \cos (\omega t)[/itex], what would the saturation current be?
The saturation current [itex]I_s \propto n_p [/itex] where [itex] n_p [/itex] is the number of incident photons per second and [itex] n_p \propto {E_0}^2 [/itex].
The given wave can be written as a sum of 3 sinusoids of frequency [itex] \omega [/itex], [itex] 2 \omega [/itex] and zero.
[itex]E=E_0 \cos (\omega t)+ \frac{E_0}{2} \cos (2 \omega t)+\frac{E_0}{2} [/itex]
Since frequence [itex] \omega [/itex] can knock out photoelectrons, so can [itex] 2 \omega [/itex]. The third term doesn't eject pholoelectrons.
I found the number of photons per second in the two waves (this is the part I suspect is wrong)
[tex] n_{p,\omega} \propto {E_0}^2 [/tex]
[tex] n_{p,2 \omega} \propto \left( \frac{E_0}{2}\right) ^2 [/tex]
and total photons incident per second would be
[tex] n_p' = n_{p,\omega} + n_{p,2 \omega} \propto \frac{5}{4} {E_0}^2 [/tex]
The saturation current in this case
[tex]I_s' \propto n_p' \propto \frac{5}{4} {E_0}^2 [/tex]
[tex] \implies I_s'=\frac{5}{4} I_s= 7.5 μA [/tex]
However, the answer given at the back of the book is 6.75 μA which is like 9/8 Is. What am I doing wrong
Terry Bing said:
The saturation current ##I_s \propto n_p## where ##n_p## is the number of incident photons per second and ##n_p \propto {E_0}^2 .##
I think you should pay closer attention to the constant of proportionality and how it is obtained. Is it the same in the two situations?
Likes Terry Bing
Thank you.
For the original wave,
[tex] n_p= \frac{c \times \frac{1}{2} \epsilon _0 {E_0}^2}{\hbar \omega} [/tex]
For the compound wave , no. of photons with energy ħω
[tex] n_{p,\omega}= \frac{c \times \frac{1}{2} \epsilon _0 {E_0}^2}{\hbar \omega} [/tex]
and no. of photons with energy 2ħω
[tex] n_{p,2 \omega}= \frac{c \times \frac{1}{2} \epsilon _0 ({E_0 /2})^2}{\hbar \times 2 \omega} [/tex]. (per unit cross section area.)
Total incident photons (per second per unit area) for the compound wave
[tex] n_p'= n_{p,\omega}+n_{p,2 \omega}=\frac{9}{8} \frac{c \times \frac{1}{2} \epsilon _0 {E_0}^2}{\hbar \omega}=\frac{9}{8}n_p [/tex]
That's not what I had in mind. The magnitude of the electric field varies with time, therefore an average needs to be taken over a cycle. The average intensity is proportional to ##E_0^2##. Does the average intensity for the two waves have the same proportionality constant?
It does, doesn't it ? Intensity depends on the amplitude and the wave velocity, which is the same for the two components.
When you say 'the two waves', do you mean the two sinusoidal components of the 2nd wave? This is what I thought you meant. Or do you mean the pure sinusoidal wave vs the compound wave?
Isn't what I wrote down in the previous reply correct? The average intensity is proportional to the amplitude for both the components, with the same proportionality constant, but the energy per photon is different. This is where I made a mistake earlier.
You have to consider that for every cycle of the ##\omega## wave you have two cycles of the ##2\omega## wave. So you should weigh the latter twice in order to find the appropriate fraction.
Related to Photoelectric effect , Superposition of sine waves
What is the photoelectric effect?
The photoelectric effect is a phenomenon in which electrons are emitted from a material when it is exposed to light. This was first observed by Heinrich Hertz in 1887 and was later explained by Albert Einstein in 1905.
What is the significance of the photoelectric effect?
The photoelectric effect provided evidence for the particle nature of light, which was a major contribution to the development of quantum mechanics. It also has many practical applications, such as in solar cells and photodetectors.
How does the photoelectric effect work?
When a photon of light hits a material, it can transfer its energy to an electron in the material. This energy is enough to overcome the binding energy of the electron, causing it to be ejected from the material as a photoelectron.
What is superposition of sine waves?
Superposition of sine waves is the principle that states when two or more sine waves of the same frequency are combined, the resulting wave is the sum of the individual waves. This is a fundamental concept in wave mechanics and is used to describe many physical phenomena.
What is the difference between constructive and destructive interference?
Constructive interference occurs when two or more waves combine to create a larger amplitude, while destructive interference occurs when two or more waves combine to cancel each other out. This is a result of the superposition of sine waves and is dependent on the phase relationship between the waves.
