Photoelectric efficiency and subatomic (ie electron or hole) momentum
In summary, the efficiency of electron excitement by photons is related to the sharing of k-space or momentum space between different orbitals. Conservation of angular momentum plays a role and is influenced by the isotropic nature of space. Orbital shape, determined by nuclear potential and electron-electron interaction, also affects the probability of interaction between a photon and electrons.
jkb_ll
The efficiency of electron excitement by photons is described as being related to how much different orbitals share the same k-space or momentum space. Is this similar to orbital shape (eg spheres, dumbells, ec)?
I have seen the equation for electron or hole momentum in different materials, but is difficult to interpret. Any answers would be v. much appreciated.
Many thanks.
JB.
So interactions between photons and electrons are just transfers of energy which conserve angular momentum. Have you studied any quantum mechanics?
Conservation of angular momentum follows from the isotropic nature of space. Since the rotation of the particle does not change the angular momentum of the particle, angular momentum must be conserved.
Orbital shape has to do with potentials (usually nuclear potentials, such as the spherical harmonics, coupled with electron-electron interaction correction terms). Conservation of angular momentum is important here as well.
One qualitative way to think about this might be to consider how a photon tracing a particular trajectory might interact with a series of electrons in different atomic orbitals. Would some orbitals offer a higher probability of interacting with the photon due to their shape or energy? Why or why not?
Hello JB,
Thank you for your question. The concept of photoelectric efficiency and subatomic momentum is an important topic in the field of quantum mechanics. In short, the photoelectric efficiency refers to the ability of a material to convert light energy into electrical energy. This conversion process is dependent on the momentum of the electrons or holes within the material.
In terms of orbital shape, the momentum of an electron or hole can be described by its wavefunction, which is a mathematical representation of the probability of finding the particle in a certain location and with a certain momentum. The shape of the orbital, such as spheres or dumbbells, can affect the probability of finding the particle at a certain location and therefore can impact its momentum.
In terms of k-space or momentum space, this refers to the representation of momentum in a three-dimensional space. Different orbitals can have different shapes in k-space, which can affect the efficiency of electron excitement by photons. For example, if an orbital has a larger overlap in k-space with a photon, it may have a higher efficiency for electron excitement compared to an orbital with a smaller overlap.
I hope this helps clarify the relationship between photoelectric efficiency and subatomic momentum. If you have any further questions, please let me know. Best of luck with your studies!
Related to Photoelectric efficiency and subatomic (ie electron or hole) momentum
1. What is photoelectric efficiency?
Photoelectric efficiency refers to the ability of a material to convert light energy into electrical energy. It is a measure of how effectively a material can convert photons (particles of light) into electrons.
2. How is photoelectric efficiency measured?
Photoelectric efficiency is typically measured by the ratio of the number of electrons emitted to the number of photons absorbed by a material. This is known as the quantum yield.
3. What is subatomic momentum?
Subatomic momentum refers to the momentum of particles smaller than an atom, such as electrons or holes. It is a measure of the movement and speed of these particles.
4. How does subatomic momentum affect photoelectric efficiency?
Subatomic momentum plays a crucial role in photoelectric efficiency as it determines the speed and direction of electrons and holes, which are responsible for generating electrical energy from light. Higher subatomic momentum can lead to more efficient conversion of light energy.
5. Can photoelectric efficiency and subatomic momentum be manipulated?
Yes, photoelectric efficiency and subatomic momentum can be manipulated through various methods such as changing the material composition, altering the energy of the incident light, or applying an external electric field. These techniques can improve the efficiency of light-to-electricity conversion in photovoltaic devices.
