Photoelectric Question (involving a photocell)
In summary: These graphs would show how the current in the photocell changes as the intensity or frequency of the incident light is changed.
slinky102
Monochromatic light of constant intensity falls on a photocell. The graph shows how the current in the photocell varies with the potential difference applied across it.
The frequency of the incident light is 6.0 x 10^14 Hz. Use the graph to estimate the work function of the metal which forms the cathode of the photocell.
Work function = ___
Add to the axes above the graph obtained when only the intensity of the light is increased. Label this graph A.
Add to the axes above the graph obtained when only the frequency of the light is increased. Label this B.
E=hf
Work function = hF0
1eV = 1.6 x 10^-19
Plancks constant (h) = 6.63 x 10^-34
Have not attempted because I have no idea where to start or go around getting the solution. And could you explain what I would do for the two graph questions. Thanks for any help in advanced. This is for As level physics.
So, you are trying to estimate the work function of the metal that forms the cathode of the photocell. The work function is the minimum amount of energy needed for an electron to escape from the metal surface.To do this, we need to use the equation E=hf, where E is the energy of the incident light, h is Plancks constant and f is the frequency of the incident light. Since we know the frequency of the incident light (6.0 x 10^14 Hz) we can calculate the energy of the incident light:E = hf = 6.63 x 10^-34 x 6.0 x 10^14 = 3.98 x 10^-19 JNow that we know the energy of the incident light, we can use this to estimate the work function. The equation for the work function is Work function = hF0, where F0 is the frequency at which the work function is equal to the energy of the incident light. Since we know the energy of the incident light (3.98 x 10^-19 J), we can solve for F0:Work function = hF03.98 x 10^-19 = 6.63 x 10^-34 F0F0 = 5.99 x 10^14 HzNow we have the frequency at which the work function is equal to the energy of the incident light (5.99 x 10^14 Hz). To find the work function, we just need to multiply this by Plancks constant (6.63 x 10^-34):Work function = hF0 = 6.63 x 10^-34 x 5.99 x 10^14 = 4.09 x 10^-19 J = 2.56 eVSo, the work function of the metal which forms the cathode of the photocell is 2.56 eV.For the two graph questions, Graph A would be the graph obtained when only the intensity of the light is increased, and Graph B would be the graph obtained when only the frequency of the light is increased.
Related to Photoelectric Question (involving a photocell)
1. What is a photocell?
A photocell is a type of electronic device that is used to detect light and convert it into an electrical signal. It is made up of a semiconductor material, typically silicon, that produces a flow of electrons when exposed to light.
2. How does a photocell work?
A photocell works by utilizing the photoelectric effect, which is the emission of electrons from a material when light is shone on it. The electrons that are emitted by the photocell create an electrical current, which can be measured and used to detect the presence and intensity of light.
3. What are the applications of photocells?
Photocells have a wide range of applications, including in automatic lighting systems, solar panels, and light sensors in cameras and other devices. They are also used in security systems, traffic lights, and even in the detection of counterfeit currency.
4. What factors affect the sensitivity of a photocell?
The sensitivity of a photocell is affected by several factors, such as the type of material used, the intensity and wavelength of the light, and the temperature. Higher intensity light and shorter wavelengths tend to increase the sensitivity of the photocell, while extreme temperatures can decrease its sensitivity.
5. How does the angle of incidence of light affect a photocell?
The angle of incidence of light on a photocell can affect its sensitivity and response time. When light hits the photocell at a perpendicular angle, it produces the strongest electrical signal. However, as the angle of incidence increases, the strength of the signal decreases, and the response time may also be affected.
16K
