Photographing Coloured Flame KCl
In summary, Tom attempted to create the "slow burn" effect seen in the video by mixing potassium chloride, a water softener, and newspaper soaked in potassium chloride. He had some success, but eventually ran into problems. He is now trying to mix the salt in methanol, soak the paper, and let it dry before burning it. He is also trying to find a source of magnesium hydroxide polycarbonate, a commonly used flame retardant, to add to the mixture.
ArtEO
Hello everyone,
I’m not a chemist at all, I studied physics which entailed a fair amount of chemistry in the learning but that was five lives ago. Nowadays I m a photographer, mostly editorial portraits but also fine arts. For my latest project I take pictures of a wide range of phenomena on very different scales, some calling for imagination, some being „cold“ descriptive.
I came across a YouTube video of someone burning a sheet of newspaper „soaked with KCl“ which then slowly burns in a stunning creeping violet flame.
I’d like very much to take closeups of this phenomenon but am very unsuccessful with my attempts so far.
I have a safe environment at hands, where I first tried to dilute KCl salt in water, soak the paper, dry it and burn it… got my regular orange flame.
I tried with alcohol (hand disinfectant) and salt again…. Same….
Please find the reference video here:
As I’m running out of ideas I wondered if someone could help me on that one. I tried to contact the person who posted the video but it’s dated 15 years ago. Thanks in advance
Chemistry news on Phys.org
Sodium is present everywhere, very difficult to avoid it. Could be what you use as KCl already contains enough to color the flame.
Two things to do: looks for a source of sodium free KCl (chemical suppliers, they always sell reagents with different purities, the purer the more expensive, I have no direct experience to tell what level of purity you need though) and use distilled water.
Likes berkeman and ArtEO
Check if the flame of that 'alcohol' in itself is colourless or orange. If it's orange then there are some additives in it and you need to change to 'clean' alcohol first to achieve some colourless flame.
To be honest, gas would be better since burning alcohol can be really dangerous.
Especially when it's colourless.
Then you can try your salt to see if it's clean enough in itself or not.
The paper can be tricky too, since some papers can contain additives, for example like Ca for whitening (yeah, it produces orange-ish flame :wink:)
Most salts are better soluble in methanol than in ethanol. So I would try this. Sodium from the paper will be a problem, too. Maybe the one who made the video used a neodymium glas filter or the like to get rid of the yellow sodium light?
Likes ArtEO
Thanks for all the answers above ! Im actually ok having a bit of orange flame appearing in the visual mix but what is really at stake for me here is the ‘slow burn ‘ effect one can see at the end of the video. Based on your recommendation, should I give it a try at mixing the KCl salt in methanol, soaking the paper and let it dry, then burn it? (I mess add n I’ll try anyway but I’d just like to understand the process a bit on the way:) )
Maybe I can add the following description from the 500g box:
  • Formula: KCL
  • Purity: 99.1%
  • Particle size: Fine
  • Food-safe, 0.9% magnesium hydroxide polycarbonate as a Antiback remedy
  • Branded Product laborladen. de
ArtEO said:
Antiback remedy
Antibacterial?
Antibacterial?
Possibly…
Using clean (distilled?) water would be better. Try using different types of paper: maybe with wool content (security papers).
Likes ArtEO
ArtEO said:
  • Formula: KCL
  • Purity: 99.1%
One ingredient caught my attention.
The magnesium hydroxide polycarbonate is a commonly used flame retardent, which is one of the things you are looking for. Maybe you could add an extra bit of that to your mixture.
That, along with the color filter suggested by @DrDu above, could be the "magic" needed.
https://www.linkedin.com/pulse/5-minutes-understand-magnesium-hydroxide-flame-retardant-leon-liu
[edit: Potassium chloride is used as a water softener salt, so you can purchase it at many hardware stores.
The smoke produced by many of these chemicals can be a serious irritant, especially for people with breathing problems. Wear a protective breathing mask while adding chemicals to the fire, and be mindful of which way the smoke is going.
(from: https://www.wikihow.com/Make-Colored-Fire)
/edit]
Cheers,
Tom
p.s. please keep us updated on your progress, and post your images here.
Likes ArtEO
FAQ: Photographing Coloured Flame KCl
What is the purpose of photographing colored flames with KCl?
Photographing colored flames with KCl (potassium chloride) is often done to study the emission spectra of potassium ions. When KCl is heated, it emits a characteristic violet or lilac flame, which can be captured and analyzed for educational, scientific, or artistic purposes.
What equipment is needed to photograph colored flames with KCl?
To photograph colored flames with KCl, you will need a Bunsen burner or a similar heat source, potassium chloride, a camera with manual settings, a tripod, and safety equipment such as goggles and gloves. A darkened room or controlled lighting environment is also recommended to enhance the visibility of the flame's color.
What camera settings should be used to capture the colored flame effectively?
To capture the colored flame effectively, use a camera with manual settings. Set a low ISO (100-400) to reduce noise, a fast shutter speed (1/100 to 1/200 seconds) to freeze the motion of the flame, and a wide aperture (f/2.8 to f/5.6) to allow sufficient light. Adjust the white balance to match the lighting conditions and consider using a tripod to stabilize the camera.
How can I enhance the visibility of the violet flame in my photographs?
To enhance the visibility of the violet flame, photograph in a darkened room to minimize ambient light. Use a black or dark background to provide contrast. Experiment with different exposure settings and consider using a UV or violet filter to emphasize the flame's color. Post-processing software can also be used to adjust the color balance and enhance the flame's visibility.
What safety precautions should be taken when photographing colored flames with KCl?
When photographing colored flames with KCl, always prioritize safety. Wear safety goggles and gloves to protect against burns and chemical exposure. Use a well-ventilated area to avoid inhaling fumes. Keep flammable materials away from the heat source and have a fire extinguisher nearby. Follow all laboratory safety guidelines and handle chemicals with care.
