Photolithography help for small features (2x2 micron boxes separated b
  • Thread starter goforhenry
In summary, the document discusses the advancements in photolithography techniques to effectively create small features, specifically 2x2 micron boxes, while addressing the challenges associated with their separation and precision. It highlights methods to enhance resolution and improve the accuracy of feature placement, which are critical for applications in microfabrication and semiconductor manufacturing.
goforhenry
Im currently working on a project where I have small features 2 x 2 micron boxes separated by 2-4 micron trenches in every direction. my current process is as follows
Piranha Clean wafers for 15 minutes
Dehydration at 150 C for 10 minutes
I spin coat the wafer with hmds at 2000 rpm for 60 seconds and soft bake at 150 C for 60 seconds
Using S1813 G2 photo resist I spin at 4000 rpm for 30 seconds and soft bake at 115 C for 60 seconds
Then I use g line (436) With an intensity of 10 and a dose of 155 mj/cm^2
Develop using developer Mf-319
The issue im having is that it seems that anything past 45 seconds my photoresist features will start to lift off. According to the website (Dupont) they were able to develop small features (lines smaller than 1 micron) with no issues. Their process is as follows,
Using photoresist S1813 G2
coat wafer with 12300 angstroms of photo resist
soft bake at 115 C for 60 Seconds
G line 150 mj/cm^2
develop doing 15 + 50 sec double spray puddle
Besides a variation in the thickness of the photoresist on the wafer and the use of hmds we follow the same recipe although I get different results. The other issue I see is that when I put my wafer in the developer I submerge the wafer for 45 seconds shaking the wafer every ten seconds. but ill have issues where I get a lot of newton rings in between my 2 x 2 micron boxes. when I developed it for 45 seconds I got the best results although for some of the wafers it seems that the developer will start to eat away at the middle of the boxes giving me a "donut" shape. Any help would be appreciated
Just throwing an idea against the wall here to see if it will stick. :bugeye:
Is there any way to put an image sensor in place of the wafer to check for a problem with the mask or optics?
FAQ: Photolithography help for small features (2x2 micron boxes separated b
What is photolithography?
Photolithography is a process used in microfabrication to transfer geometric patterns onto a substrate. It involves the use of light to expose a photosensitive material (photoresist) that is applied to the substrate, allowing for the creation of small features, such as integrated circuits and microelectromechanical systems (MEMS).
How can I achieve small feature sizes like 2x2 microns?
To achieve small feature sizes such as 2x2 microns, it is essential to use high-resolution photolithography techniques, including advanced mask designs, optimized exposure conditions, and high-quality photoresists. Additionally, employing techniques like phase-shift masks or using multiple exposure steps can enhance resolution.
What type of photoresist should I use for small features?
For small features like 2x2 microns, you should consider using a negative-tone or positive-tone photoresist with high resolution and sensitivity. Specialty resists designed for high aspect ratios and fine patterning, such as chemically amplified resists, are often recommended for achieving precise and detailed patterns.
What are the challenges in photolithography for small features?
Challenges in photolithography for small features include issues such as diffraction limits, photoresist resolution, and pattern distortion. Additionally, maintaining uniform exposure, controlling the development process, and ensuring proper alignment during multi-layer fabrication can also pose significant challenges.
How can I improve the separation between features?
To improve the separation between features, careful design of the mask layout is crucial. Techniques such as using larger gaps in the mask, optimizing exposure dose, and employing spacer techniques can help enhance feature separation. Additionally, ensuring proper alignment and using high-quality substrates can also contribute to better spacing.
45K
