Photometry: Determining a binary star system.
In summary: The colour index is a measure of how much emission is at each wavelength, not how bright the object appears at each wavelength.
Lavabug
866
37
By performing CCD photometry on a pair of nearby stars A and B we obtain their relative magnitudes in the V filter and their colors:
Star A: mV = 8.70 , (B − V )= 1.30
Star B: mV = 11.90 , (B − V )= 1.81
Star A is known to be a of a main sequence K0V type, while no other information on Star B is available.
Argue if this consists of a visual binary system or if B is a background star.
[tex]m_{\lambda}(N stars) = -2.5log(\sum10^{.0.4m_{\lambda}_i})[/tex]
Not sure what to do. Using the expression above, I found the apparent magnitude for the system as a whole and it came out brighter than A (as expected), but by very little: 8.645. What do I need to look for to determine if its a binary or not?
It seems to me that, based on the colour of star B, you can figure out it's spectral type. At the very least, you know that it is redder than K0. Now, if it's a binary, then you also know that both stars are at the same distance from Earth. Therefore the difference in their apparent magnitudes is the same as their difference in absolute msgnitudes. So, under this assumption, you know how much dimmer (intrinsically) star B is than star A. Ask yourself whether it makes sense that a star on the main sequence that is 0.5 mag redder than a K0 star would also be that much dimmer. If it does make sense, then this can be a binary. If it doesn't, then the only explanation must be that star B is in fact much farther away.
Thanks for the quick reply. How do I know that star B is redder than K0? Sorry if this sounds elementary, I'm just getting acquainted with calculating color indices, magnitudes etc.
I'm attaching the table provided for problem-solving, it claims different values for a K0V star(I think everything is shifted by one unit), and according to the table, star B is a G0V type (comparing (B-V) indices), which would imply it is brighter than K0V on the absolute scale. (am I doing this right?)
But on the apparent mag. scale star A is brighter, hence it is much closer than star B, am I on the right track? How far apart (or different in apparent magnitude) do they need to be in order to discard the possibility of it being a binary system?
  • table.pdf
I know star B is redder because its B-V colour index is larger. Here is how to interpret the colour index:
B is the star's apparent magnitude in the B (blue) photometric band, which, if I recall correctly, uses filters centred on ~400 nm wavelength.
V is the star's apparent magnitude in the V (visual) photometric band, which, if I recall correctly, uses filters centred on ~550 nm wavelength.
If B-V is postiive, it means that B > V. Recall, that larger apparent magnitude = dimmer. Therefore, having B-V > 0 means that the star's observed B-band brightness is less than the its V-band brightness. The larger the colour index value is, the less emission is being received in the B-band relative to the V-band, and the (hence we infer) the redder the emission spectrum of the object must be. Since star B's colour index of 1.81 is larger than star A's colour index of 1.30, we conclude that star B has a redder spectrum (more emission at longer wavelengths, less at shorter wavelengths).
No, I don't think you're doing this right. Even if everything were shifted by 1 unit, I have no idea how you'd get a spectral type G0V for star B, that just doesn't make any sense whatsoever. In any case, I don't think that everything is shifted by 1 unit. If it were, then the value of K0's B-V index in the table would be 0.30. It is not. The reason why the observed K0 colour index stated in the problem is greater than the theoretical one in the table is probably because of interstellar reddening. However, if both stars are in a binary, then they're at the same distance and hence you can assume they're both reddened by the same amount. So, although both of their colour indices will have changed, the difference between their colour indices will be the same as it was without the reddening. From what I just said in the previous sentence, since star B's colour index is about 0.5 mag larger than a K0 star, the table would seem to indicate that it is of type K7.
So, under the assumptions we've made, star B must be of type K7. Now, compare the absolute magnitudes of K0 and K7 main sequence stars. According to the table, a K7 is only 2.2 mag dimmer than a K0. Yet, the observations show that star B is a whole 3.2 mag dimmer than star A. It doesn't fit where it should on the main sequence for a K7 star. The only thing we can conclude is that our initial assumption about the stars being at the same distance must have been wrong.
As a scientist, your response could be:
To determine if this system is a binary star system or if Star B is a background star, we need to consider several factors. The first factor is the relative magnitudes of the stars in the V filter. From the given data, Star A has a magnitude of 8.70 while Star B has a magnitude of 11.90. This indicates that Star A is significantly brighter than Star B.
The second factor to consider is the colors of the stars. Star A has a (B-V) color index of 1.30, which is consistent with a main sequence K0V type star. However, we do not have any information about the type of star Star B is. If Star B is also a main sequence star, we would expect its (B-V) color index to be similar to that of Star A. However, Star B has a (B-V) color index of 1.81, which is significantly redder than Star A. This could suggest that Star B is a background star, as background stars often have a redder color index due to their greater distance from us.
Another factor to consider is the distance between the two stars. If they are close together in the sky, it is more likely that they are a visual binary system. However, if they are further apart, it is more likely that Star B is a background star.
In conclusion, based on the given data, it is more likely that Star B is a background star rather than a companion to Star A in a binary system. However, further observations and data may be needed to confirm this.
Related to Photometry: Determining a binary star system.
1. What is photometry?
Photometry is the measurement of the intensity or brightness of light emitted from a celestial object. It is an important tool in astronomy for studying various objects such as stars, planets, and galaxies.
2. How is photometry used to determine a binary star system?
Photometry is used to determine a binary star system by measuring the changes in brightness of the two stars as they orbit each other. By analyzing the light curves, which show the changes in brightness over time, scientists can determine the orbital period, distance, and other properties of the stars in the system.
3. What types of telescopes are used for photometry?
There are several types of telescopes that can be used for photometry, including ground-based telescopes, space telescopes, and specialized photometers. Ground-based telescopes are often used for long-term monitoring of binary star systems, while space telescopes can provide more accurate and higher resolution data. Specialized photometers are designed specifically for photometry and can provide precise measurements of light intensity.
4. How does photometry help us understand binary star systems?
Photometry helps us understand binary star systems by providing information about the physical properties of the stars, such as their mass, temperature, and luminosity. It also allows us to study the orbital dynamics of the stars and the effects of their interactions on each other. This information can help us better understand the evolution and formation of binary star systems.
5. What challenges are involved in photometry of binary star systems?
One of the main challenges in photometry of binary star systems is separating the light from the two stars. This can be difficult because the stars are often close together and their light can overlap, making it hard to distinguish the individual signals. Other challenges include atmospheric effects, instrumental noise, and the need for precise and accurate measurements over long periods of time.
  • Astronomy and Astrophysics
