Photon absorption and speed of wave function propagation....
In summary: And measurement operators over a spacelike separation commute, so there's no causality problem.In summary, the conversation discusses the speed of information propagation in quantum field theory (QFT) and its relationship to special relativity. It is mentioned that in QFT, there is no unique configuration space and the concept of "wave function" is not the same as in ordinary quantum mechanics. It is also noted that in QFT, the property of spacelike separated measurements commuting ensures that relativistic causality holds, and there is no meaningful "speed" of propagation for the wave function. The issue of entanglement is brought up, but it is stated that even in cases involving entanglement, the concept of "speed of wave
asimov42
377
Hi all,
Whew, last question for a while: I think I already know the answer, but want to confirm (e..g, I think this thread basically answers the question, https://www.physicsforums.com/threads/propagation-of-wavefunction.152053/)
As an example, let's say I have an electron (in free space or bound to an atom) that absorbs a photon and transitions to a higher energy state. I understand that in QFT, this transition is not instantaneous (although very fast) - in terms of the electron probability distribution (square of wave function) for, e.g., the bound electron case, there should be a decrease in the probability of being found in one orbital over time, with an increase in the probability of being found in a higher orbital over time (again, with the time scale of this transition being very short).
Now, the question: the electron wave function will change as a result of the photon absorption - however, the propagation of the change in the wave function must not exceed the speed of light to agree with special relativity? I realize that that wave function lives in Hilbert space, so I guess what I'm asking is: the speed at which 'information' about the absorption of the photon propagates through the relevant field in spacetime should be c or less - correct? Otherwise, e.g., nearby particles (other field excitations) would feel in influence of the change faster light.
Thanks!
Yes, the information propagates at less than or equal to c. But there's a caveat because of the wave function, and this may be the reason no one answered this simple question. If the electron were entangled with another one, far away, some people say that influence propagates instantaneously (non-locally). It gets into one of those endless QM interpretation debates. If you don't care about entanglement there's no problem. But if you're thinking of entanglement, my advice would be: don't.
Where do you get this understanding from? It is not really correct. A correct statement would be that QFT does not give a meaningful "speed" to such a transition.
If you are thinking about QFT (which you have to if you're thinking about relativistic QM), then there isn't a "wave function" in the sense of ordinary QM. An ordinary QM wave function is a function defined on the configuration space of the system; but in QFT, there is no unique "configuration space" because there is no preferred frame. You have to think of things in terms of spacetime. (Actually, QFT is more often done in momentum space, which is easier to work with.) In spacetime terms, QFT is consistent with relativistic causality, which means information doesn't propagate faster than ##c##. But "information" is not the same as "wave function" (or the things that play similar roles to wave functions in QFT); those things don't have a meaningful "speed of propagation".
Even in non-relativistic QM, where you can talk about wave functions, probability distributions in space, orbitals, etc., "speed of propagation" still isn't a meaningful concept for those things. "Speed" (more precisely velocity) can be an observable, but an observable is not the same as a wave function (or those other things).
In QFT, yes. But as I noted in my other post just now, "information" in QFT is not the same thing as the QFT counterpart of "wave function". Wave functions, or their QFT counterparts, don't have a meaningful speed of propagation, and you can't really assign a meaningful "time" to transitions of the sort the OP is describing.
That's the point I was trying to make re. entanglement. But perhaps that doesn't cover all non-negligible cases? Does "speed of wave function propagation" ever become an issue in QFT, apart from entanglement?
I would say no, whether entanglement is involved or not. In QFT, the property that ensures that relativistic causality holds is that spacelike separated measurements commute, i.e., their results are independent of the order in which they are performed. This holds even though there are nonzero amplitudes for correlation between spacelike separated measurements (which is the property of entanglement that often makes people think that there is some sort of FTL "propagation" going on). So in QFT the problem of "propagation speed of the wave function" doesn't really exist; the thing to look at is what measurement operators commute.
Likes vanhees71 and secur
Related to Photon absorption and speed of wave function propagation....
1. What is photon absorption?
Photon absorption is the process by which a photon, a particle of electromagnetic radiation, is absorbed by an atom or molecule, causing an electron to move to a higher energy level.
2. How does photon absorption affect the speed of wave function propagation?
Photon absorption can increase the speed of wave function propagation, as the absorption of a photon causes an electron to jump to a higher energy level and move faster. However, other factors such as the medium in which the photon is traveling can also influence the speed of wave function propagation.
3. What factors determine the speed of wave function propagation?
The speed of wave function propagation is determined by the energy of the photon, the properties of the medium it is travelling through, and any interactions or absorptions that may occur along its path.
4. Can the speed of wave function propagation be faster than the speed of light?
No, according to the theory of relativity, the speed of light is the fastest speed at which anything in the universe can travel. Therefore, the speed of wave function propagation cannot exceed the speed of light.
5. How is the speed of wave function propagation related to the concept of quantum entanglement?
Quantum entanglement is a phenomenon in which two particles become connected in such a way that the state of one particle is dependent on the state of the other, regardless of the distance between them. The speed of wave function propagation plays a role in this phenomenon, as it determines how quickly the state of one particle will be affected by changes to the other particle. This has been observed to occur instantaneously, which suggests that the speed of wave function propagation may be faster than the speed of light, but more research is needed to fully understand this concept.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
