Photon and anti-photon annihilation?
In summary, the conversation discusses the concept of photon and "anti-photon" annihilation in quantum field theory. It is explained that while other particles can appear and quickly annihilate each other, the photon is its own anti-particle. The difference between photons and other particles is that the Number Operator of photons is not conserved, but rather the sum of their energies. It is also mentioned that in theory, photons can annihilate through a specific process, but it has not been directly observed. The idea of negative energy for real photons is also discussed, with the conclusion that while it is possible for one particle to have negative energy, overall energy conservation is still maintained. Finally, the conversation touches on the experiment of light-by-light scattering,
Goliatbagge
Photon and "anti-photon" annihilation?
In quantum field theory pairs of virtual particles can appear from vacuum and quickly annihilate each other, for example an electron/positron or a proton/antiproton. But how does this work with photons?From what I know, the photon is its own anti-particle. So the "anti-photon" is just another photon. But how can a real photon annihilate an other "real" photon? Real photons are everywhere, so in that case photons would annihilate each other all the time?
The difference between photon and other massive particles is that the Number Operator of photons is not conserved. What is conserved is the sum of energy of the photons not their number.
So if two photons appear from vacuum their sum of energy should be zero? Wouldn't that mean that one of them must have negative energy?
In principle, photons can annihilate, e.g., through the QED process [itex]\gamma+\gamma \rightarrow e^+ + e^-[/itex]. I've never heard that anyone has been able to observe this process, however.
I think that this process has in fact been observed - even for real photons:
Positron production in multiphoton light-by-light scattering
... followed by
a collision between the high-energy photon and several laser photons to produce
an electron-positron pair. These results are the rst laboratory evidence for
inelastic light-by-light scattering involving only real photons.
Likes 1 person
I don't believe so. Consider the creation of an electron and a positron. The total mass-energy would be positive, but because they only exist for an instant before annihilation, no conservation rules are violated.
Also, note that "real" photons are not created directly from the vacuum, but from accelerated charges.
Since energy is conserved, the total mass-energy will be zero, just like the vacuum they emerged from. Virtual particles don't have to obey the usual relationship between energy and momentum, and it's perfectly OK for one particle or the other to have negative energy.
What do you mean by "total mass-energy"? Of course the two real photons are onshell and the scattering process [itex]\gamma + \gamma \rightarrow e^+ + e^-[/itex] obeys energy-momentum conservation. You can analyze the kinematics as usual with help of the Mandelstam variables.
The experiment is about a scattering process with REAL photons (originating from laser sources). Of course, these photons have positive energies (frequencies).
FAQ: Photon and anti-photon annihilation?
1. What is photon and anti-photon annihilation?
Photon and anti-photon annihilation is a process where a photon (a particle of light) and an anti-photon (its antiparticle) collide and are converted into other particles, such as an electron-positron pair.
2. How does photon and anti-photon annihilation occur?
Photon and anti-photon annihilation occurs when the two particles come into contact and are able to interact with each other. This can happen in a variety of scenarios, such as in particle accelerators or in the early stages of the universe.
3. What is the significance of photon and anti-photon annihilation?
Photon and anti-photon annihilation plays a crucial role in understanding the behavior of matter and energy at the subatomic level. It also helps to explain the origins of the universe and the formation of particles in the early stages of the Big Bang.
4. Can photon and anti-photon annihilation be observed?
Yes, photon and anti-photon annihilation has been observed in experiments using particle accelerators. Additionally, the after-effects of annihilation, such as the creation of new particles, can also be detected and studied.
5. Is photon and anti-photon annihilation a reversible process?
Yes, photon and anti-photon annihilation can be reversed through a process called pair production. This is when a high-energy photon can be converted into an electron-positron pair, essentially reversing the annihilation process.
