Photon Antibunching: Clarifying Inverse Not Necessarily True
  • Thread starter Niles
  • Tags
    Photon
In summary, the conversation discusses the relationship between sub-Poissonian statistics and photon antibunching. The inverse is not always true, as demonstrated in the paper "Transition from Antibunching to Bunching in Cavity QED" by M. Hennrich et al. The paper shows that antibunching can occur without sub-Poissonian statistics due to the fluctuation of the number of emitters. The conversation also mentions a two-mode state that is both bunched and has sub-Poissonian photon statistics, which may seem contradictory but has been demonstrated.
Niles
1,866
Hi
My teacher said that sub-Poissonian statistics (g(2)(0)<1) implies photon antibunching (g(2)(t)>g(2)(0)), but that the inverse is not necessarily true, since g(2)(t) = 1 for t very large. I am not quite sure I can see why the inverse is not the case.
Can anyone clarify this?
Niles.
You can find a demonstration of such a case for example in "Transition from Antibunching to Bunching in Cavity QED" by M. Hennrich et al., Phys. Rev. Lett. 94, 053604 (2005). If you do not have access to PRL, you can also find the paper on the pages of the Max Planck institute here: http://www.mpq.mpg.de/cms/mpq/en/departments/quanten/homepage_cms/publications/papers/library/PRL94p053604_Hennrich.pdf"
In that case antibunching without sub-Poissonian statistics occurs because they study the emission of a number of single atoms falling through a cavity and the dependence on the mean atom number. Although each atom is in principle a source of non-classical light and should emit light showing sub-Poissonian statistics, the actual number of photons falling through the cavity is following a Poisson distribution which then alsomanifests in the emission statistics, yielding antibunching, but no sub-Poissonian statistics because the number of emitters is fluctuating.
Thanks for the paper -- I will have to read it. My teacher said that a two-mode state being bunched and having sub-Poissonian photon statistics has been constructed. I cannot quite see how this is possible since we know that sub-Poissonian => antibunching, then how does it make sense to have bunched light which is sub-Poissonian?
Thanks for your time.
FAQ: Photon Antibunching: Clarifying Inverse Not Necessarily True
What is photon antibunching?
Photon antibunching is a phenomenon observed in certain types of light sources, where the arrival of photons is not evenly distributed over time. Instead, there is a tendency for photons to arrive in clusters or bunches, with longer intervals of time between the bunches.
Why is it important to clarify that inverse not necessarily true in relation to photon antibunching?
It is important to clarify this because there is a common misconception that photon antibunching always implies an inverse relationship between the number of photons and the probability of their arrival. However, this is not always the case and can lead to misunderstandings in data analysis and interpretation.
What factors can affect the degree of photon antibunching?
The degree of photon antibunching can be affected by various factors, such as the type of light source, the temperature of the source, and the detection method used. Additionally, the presence of other particles or molecules in the surrounding environment can also influence photon antibunching behavior.
How is photon antibunching measured?
Photon antibunching can be measured by analyzing the photon count distribution over time using techniques such as photon correlation spectroscopy or time-correlated single photon counting. These methods allow for the calculation of the second-order correlation function, which can indicate the degree of antibunching.
What are the potential applications of understanding photon antibunching?
Understanding photon antibunching can have various applications in fields such as quantum optics, photonics, and biophysics. It can also be used in the development of new technologies, such as single-photon sources, quantum cryptography, and super-resolution microscopy.
