Photon, black hole, Wikipedia quote
In summary, the task of measuring an object's position using photons can potentially create a minuscule black hole if the photons are energetic enough. This is due to the collision between the photons and the object, which can create new particles with enough mass to form a black hole. The concept of a Planck length as the minimum measurable distance can also be derived from the Heisenberg uncertainty principle. This result demonstrates the potential for a more unified theory that combines both quantum mechanics and general relativity.
pdxjjb
I found the following in Wikipedia on the page http://en.wikipedia.org/wiki/Plank_length:
The task is to measure an object's position by bouncing electromagnetic radiation, namely photons, off it. The shorter the wavelength of the photons, and hence the higher their energy, the more accurate the measurement. If the photons are sufficiently energetic to make possible a measurement more precise than a Planck length, their collision with the object would, in principle, create a minuscule black hole.
Question: what is the mechanism through which the interaction of a photon with an object could (even in principle) cause the object to become a "minuscule black hole"? I understand that this is a question in principle only, i.e. the required energy is far beyond any technology we can conceive today, any cosmic rays we might observe with technology like Auger, etc.
My first thought was that the photon might accelerate the object, increasing its so-called "relativistic mass" such that it falls within its own Schwarzschild radius. But this appears to be false reasoning: http://www.physics.adelaide.edu.au/~dkoks/Faq/Relativity/BlackHoles/black_fast.html
I am a layperson and don't have the skills to go about finding a better answer myself.
Thanks in advance,
Jeff
Im not exactly sure, but I think this would be similar to what they do in particle accelerators. They localize enough energy to create particles (i.e. through collisions). A photon colliding with a particle can create new particles, based on the energy of the collision. Therefore a photon with enough energy would be able to create enough mass to form a black hole.
Im no where near an expert on this subject, but from what I've read I think that's the explanation for this.
wow I've actually never heard of this before but its an incredibly interesting result. Two supposedly separate theories give the same result to a problem, but neither can explain why they give the same result. Doesn't that almost prove that there's a more unified theory that explains both QM and GR?
Thanks very much for the link.
I never thought of it as two separate paths to the same result. I think of it as one path that requires elements of both theories: the need to interact in order to observe (QM) and the creation of a black hole (GR). Can you say a little more about your last post?
well I can't remember the exact derivation, but I am pretty sure the Planck length being a "minimum" measurable distance can also be derived from the heisenburg uncertainty principle. That was the 2nd path to the same result. Even though the black hole thing involves some QM, Id really classify it as a GR result.
Related to Photon, black hole, Wikipedia quote
What is a photon?
A photon is a fundamental particle that is responsible for carrying electromagnetic radiation, such as light. It has no mass and travels at the speed of light.
What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. It is formed when a massive star collapses in on itself.
How are photons related to black holes?
Photons can be affected by the strong gravitational pull of a black hole. They can be captured by the black hole's gravity and pulled into it, or they can be bent and distorted as they pass near the black hole.
What is the relationship between photons and energy?
Photons are a form of energy and are the basic unit of all electromagnetic radiation. They have no mass, but they do have energy and momentum. The energy of a photon is directly proportional to its frequency.
What is the relevance of the Wikipedia quote in relation to photons and black holes?
The Wikipedia quote is likely discussing the concept of Hawking radiation, which is a theory that suggests black holes emit radiation, including photons, due to quantum effects. This quote highlights the ongoing scientific debate and research surrounding the relationship between photons and black holes.
  • Quantum Physics
  • Cosmology
  • Quantum Physics
  • Beyond the Standard Models
  • New Member Introductions
