- #36
- 6,993
- 2,470
rbj said:if no concept of name "relativistic mass" and [itex]m[/itex] is created, what is the means of getting to the true momentum of a body of mass [itex]m_0[/itex] as observed by someone as it is flying by at velocity [itex]v[/itex]? how do we get to:
[tex]p = m_0 v \left( 1 - \frac{v^2}{c^2} \right)^{-\frac{1}{2}}[/tex] ?
let's assume we know about the invariancy of [itex]c[/itex], time dilation, length contraction, Lorentz transformation of coordinates, and velocity addition. without an idea of a different "relativistic mass" and plugging that into what we previously defined momentum to be [itex] p = m v [/itex], how do we get the more accurate expression of momentum above?
Maybe I misspoke or am misunderstanding something. Let me be clear (at the expense of possibly being redundant).
I'm advocating not to use the relativistic mass [tex]m[/tex], however, one could use the above expression... and one could keep the grouping [tex]m_0\left( 1 - \frac{v^2}{c^2} \right)^{-\frac{1}{2}} [/tex] together if it helps you calculate.
How would I obtain your formula for the "relativistic momentum", that is, to say, the "spatial-component of the spacetime momentum vector" (or simply, the "spatial-component of the 4-momentum")?
For particles with nonero rest-mass, we write the 4-vector expression
[tex]\tilde P=m_0\tilde v[/tex], (quite a natural generalization)
where [tex]\tilde v[/tex] is the 4-velocity [the unit tangent-vector to the worldline...] of the particle, and
the norm of the 4-momentum is (up to conventional factors of c) the rest mass [tex]m_0[/tex]. This is product of an observer-independent scalar and an observer-independent vector.
The spatial component of this 4-vector is [tex](norm)\sinh(rapidity)[/tex], and the temporal component is [tex](norm)\cosh(rapidity)[/tex], where the rapidity [tex]\theta[/tex] is the spacetime-angle from your observer's worldline to the worldline of the object.
In this language, the fractional relative velocity ([tex]\beta[/tex]) is [tex]\frac{v}{c}=\tanh\theta[/tex];
the combination [tex]\left(1-\left(\frac{v}{c}\right)^2\right)^{-1/2} =\cosh\theta[/tex], aka [tex]\gamma[/tex];
the combination [tex]\left(\frac{v}{c}\right)\left(1-\left(\frac{v}{c}\right)^2\right)^{-1/2} =\sinh\theta[/tex], aka [tex]\beta\gamma[/tex].
So, the spatial component of the 4-momentum is
[tex]\tilde P_{spatial}=m_0 \sinh\theta=m_0 v \left(1-\left(\frac{v}{c}\right)^2\right)^{-1/2}[/tex] (after restoring the c's)
[tex]\tilde P_{temporal}=m_0 \cosh\theta=m_0 \left(1-\left(\frac{v}{c}\right)^2\right)^{-1/2}[/tex] (after restoring the c's)
You'll recognize this as the "relativistic momentum" and the "relativistic energy"... up to appropriate factors of c.
For a photon, the 4-momentum has a tangent-vector along the light cone... so it has zero norm. Further, the magnitudes of its temporal and spatial components are equal. (Rapidity cannot be used here because it is inifinite.) In spite of this, its spatial and temporal components of the 4-momentum are still interpreted as relativistic momentum and relativistic energy, and are proportional to the frequency of the photon.
By the way... to introduce force, one can write the 4-vector equation
[tex]\tilde F=m_0\tilde a = \frac{d}{d\tau}\tilde p [/tex], (quite a natural generalization).
As you may be aware, there are problems writing down an expression like
"[tex]\vec F=m\vec a[/tex]", where [tex]\vec F[/tex] and [tex]\vec a[/tex] are [spatial] relativistic vectors.
Not quite a whole textbook... but a syllabus for teaching introductory kinematics and dynamics using [Galilean] spacetime concepts... to facilitate the future transition to Special Relativity.rbj said:are you working on an intro textbook? however it is, this sounds very cool.
