Photon mean free path (regarding CMB black body assumption)
In summary: It's not possible to say that a certain percentage of individual photons are polarized, as it is a property of the overall signal. So "10% of the signal" means that, on average, 10% of the signal at any given point on the sky is polarized.
bahamagreen
1,014
52
Per Wikipedia (Outer Space) referencing Davies, P. C. W. (1977), "...the mean free path of a photon in intergalactic space is about 10E23 km, or 10 billion light years."
Per Lawrence Krauss (1999), it is longer than the size of the visible universe.
What is the current thinking about this?
Space news on Phys.org
Ten billion light years isn't longer than the size is the visible universe, so I think you've made a mistake there.
But the way this is measured is via the CMB, which in the 13 billion or so years since it was emitted, roughly 93% of the photos haven't scattered.
Likes JMz
How am I making a mistake by asking about the discrepancy between to values of the photon MFP in space?
I looked up the MFP of a photon a while back and found the Wiki reference to Davies 1977 (over a decade before COBE) of 10 billion light years. Science topics on Wiki are pretty well managed by the university academics, so I thought perhaps the forty year old referenced figure was still in good standing.
Lately I'm reading Krauss 1999 about the logical steps of interpreting the CMB. He italicizes a caveat that assumes the photons have not been subject to having been scattered, absorbed, re-emitted, etc. to which he subsequently returns and asserts without reference that the MFP is greater than the visible universe (so he takes the assumption as being met).
"Consider the microwave background that has a black body spectrum with maximum energy at some frequency (f) associated with a temperature (T) of 2.7K (see figure 2.1). If this light has not been interacting with anything else that might have kept it at a fixed temperature, then earlier it must have had a spectrum with maximum energy at some higher frequency (f '), since each light wave has been "redshifting" during the expansion." (Krauss' italics)
If the MFP were an independent figure not dependent on CMB and figured to be greater than the observable universe, then the CMB black body assumption would be considered met. However, if the MFP were inferred via CMB and yet the CMB interpretation were based on MFP assumptions, how is this not problematic?
The mistake is that 10 billion light years is far too short. This is probably because the mean free path was not well-measured until WMAP in the early 2000's, so the 1977 estimate is naturally quite far off.
The way this is parameterized in modern experiments is via ##\tau##, which is the optical depth to the CMB. The portion of photons which do not scatter between the CMB and us are ##e^{-\tau}##.
Polarization is the critical component in measuring this parameter (which was first done on large scales through WMAP) because the scattered photons become polarized, which ends up creating a relationship between CMB temperature anisotropies and polarization. Now, with the Planck satellite, our current best estimate for the optical depth is ##\tau = 0.05##, indicating that around 95% of photons between us and the CMB never scattered (my earlier estimate was from memory based on earlier WMAP measurements).
The reason why the mean free path isn't used, by the way, is that it changes over time as the universe becomes less dense. You could interpret the ##\tau## as a mean free path, but you wouldn't get a meaningful answer because the universe will expand quite a bit in the time it takes a photon to cross that much distance.
kimbyd said:
...around 95% of photons between us and the CMB never scattered...
"...the CMB is linearly polarized at the 10% level due to Thomson scattering of photons off free electrons in the surface of last scattering. CMB polarization was first detected by DASI from the South Pole in 2002 and has since been observed by many other experiments."
https://www.cfa.harvard.edu/~cbischoff/cmb/
Does "polarized at the 10% level" mean only 10% of the photons are polarized or does it mean that all the photons are polarized 10%?
It means that roughly 10% of the signal we receive is polarized at any point on the sky.
Does "10% of the signal" mean 10% of the photons are polarized or all the photons are polarized 10% or the average polarization is 10%?
The polarization is only measured in the aggregate. The total signal at each point on the sky is polarized by some amount.
Related to Photon mean free path (regarding CMB black body assumption)
1. What is the photon mean free path?
The photon mean free path is the average distance that a photon travels before interacting with matter. In other words, it is the average distance between two consecutive collisions of a photon with particles in a medium.
2. How does the photon mean free path relate to the CMB black body assumption?
The CMB black body assumption states that the cosmic microwave background radiation (CMB) has a black body spectrum, meaning that it follows a specific distribution of photon energies. The photon mean free path is important in this assumption because it determines the distance over which photons can travel without being scattered or absorbed by matter. This allows us to understand how the CMB radiation has been affected by the universe's expansion and the evolution of matter since the Big Bang.
3. What factors affect the photon mean free path?
The photon mean free path is affected by the density and composition of the medium through which the photons are traveling. Higher densities and heavier elements lead to shorter mean free paths, as there is a greater chance of photon interactions. In addition, the energy of the photons also plays a role, as higher energy photons have shorter mean free paths due to their increased likelihood of interactions.
4. How is the photon mean free path measured?
The photon mean free path can be measured through observations of the CMB radiation. By studying the intensity and temperature fluctuations of the CMB, scientists can infer the mean free path of the photons. This information can also be used to validate the CMB black body assumption and provide insights into the composition and evolution of the universe.
5. What is the significance of the photon mean free path in cosmology?
The photon mean free path is a crucial parameter in understanding the evolution of the universe. It allows us to study the interactions between photons and matter, which provide valuable insights into the early stages of the universe's formation. By studying the CMB radiation and its mean free path, scientists can also gain a better understanding of the properties of dark matter and dark energy, two mysterious components that make up the majority of our universe.
  • Cosmology
  • Electromagnetism
