Photon Rocket vs Conventional Propellant Rocket
In summary, a photon rocket uses photons as its propellant and has less momentum than a conventional rocket.
sanman
745
24
I want to ask about the differences between a photon rocket and a rocket which uses conventional propellant.
A conventional rocket shoots exhaust matter out the back end, resulting in impulse and acceleration.
A photon rocket shoots photons out the back end, resulting in impulse and acceleration.
The exhaust propellant of a conventional rocket transfers some of its momentum to the rocket, which results in the impulse and acceleration for the rocket. This leaves the exhaust propellant particles with lower velocity (energy) than they otherwise would have left with.
The photon exhaust of a photon rocket transfers some of its momentum to the rocket, which results in the impulse and acceleration for the rocket. This leaves the photon exhaust particles with lower frequency (energy) than they otherwise would have left with.
A conventional rocket can incorporate an expansion nozzle and bell to drain/transfer even more momentum from the propellant exhaust particles to the rocket than would have otherwise been possible without the nozzle and bell, thus resulting in a more efficient rocket. This happens because the expansion nozzle and bell provide more collision opportunities for the exhaust propellant particles to transfer momentum to the rocket.
What is the analogous counterpart to the nozzle and bell, for a photon rocket? Is there anything?
Science news on Phys.org
Hmmm... perhaps a parabolic reflector or lens to focus the outgoing rays?
Can a parabolic reflector or lens increase the opportunities for momentum transfer to the rocket from each photon?
That I don't know. I was thinking more along the lines of making each photon move opposite to the direction of the rocket to increase the amount of thrust provided in that direction instead of having it simply be ejected in a large cone. But I admit I'm not too familiar with the design of photon rockets.
Wiki has a small note on this: http://en.wikipedia.org/wiki/Photon_rocket
Photons could be generated by onboard generators, as in the nuclear photonic rocket. The standard textbook case of such a rocket is the ideal case where all of the fuel is converted to photons which are radiated in the same direction. In more realistic treatments, one takes into account that the beam of photons is not perfectly collimated, that not all of the fuel is converted to photons, and so on.
Using photons as propellant isn't quite the same as using matter as propellant, since photons behave differently than matter does.
For instance, the propellant matter for a conventional rocket doesn't disappear, but meanwhile photons can readily be converted into other forms of energy and seem to "disappear" from the ledger. You can do a massflow balance for a conventional rocket, but a mass flow balance for a photon rocket seems more tricky, because photons can do more things to turn their apparent mass into something else.
FAQ: Photon Rocket vs Conventional Propellant Rocket
What is a photon rocket?
A photon rocket is a type of propulsion system that uses the momentum of photons (particles of light) to generate thrust. This is achieved by directing a beam of photons in one direction, which in turn pushes the rocket in the opposite direction.
How does a photon rocket compare to a conventional propellant rocket?
A photon rocket is fundamentally different from a conventional propellant rocket. While a conventional rocket carries fuel and uses the chemical reaction of burning fuel to generate thrust, a photon rocket does not require any fuel and instead relies on the momentum of photons for propulsion. This means that a photon rocket can potentially reach much higher speeds and travel longer distances compared to a conventional rocket.
What are the advantages of using a photon rocket?
Some potential advantages of using a photon rocket include faster travel speeds and longer travel distances, as well as a reduced need for refueling or resupplying. Additionally, since a photon rocket does not rely on burning fuel, it produces no exhaust and is therefore more environmentally friendly.
Are there any limitations or challenges associated with using a photon rocket?
One major limitation of a photon rocket is that it requires a significant amount of energy to generate the necessary photon beam. This energy can come from a variety of sources, such as solar panels or nuclear reactors, but it is still a significant technical challenge. Additionally, a photon rocket would only be effective in a vacuum, so it would not be suitable for use in atmospheric conditions.
Is there any ongoing research or development in the field of photon rockets?
Yes, there is ongoing research and development in the field of photon rockets. Some current efforts include finding more efficient ways to generate and direct photon beams, as well as exploring potential applications for photon rockets in space travel and exploration. However, there are still many technical challenges that need to be addressed before photon rockets can be used on a larger scale.
