- #36
Ibix
- 14,141
I believe that's exactly what I just said. The point you seem to be failing to grasp is that time dilation comes from the ##g_{tt}## element of the metric (expressed in Riemann normal coordinates). Newtonian physics also arises from the approximation that the ##g_{tt}## component of the metric is the only one that is significantly different from flat. So adding time dilation on top of Newtonian physics would be double-dipping the ##g_{tt}## component. If it works (and you'd need to develop some such theory mathematically to show that it did, because it isn't clear what adding time dilation to Newtonian gravity would mean or even, as Dale points out, that there's a self-consistent way to do it) it would most likely be pure luck and not a generalisable theory.jeremyfiennes said:That a new theory supplants an old one, does not make the old one is invalid over the range it covers.
The PPN approximation allows you to add in the effects of the ##g_{rr}## component being different from its flat spacetime value. That gets you the full GR answer in this case.
