Photon Travel: Is Our Universe a Single Point?
In summary, the popular misconception is that time dilation and length contraction do not apply to photons because their reference frame is at rest. This is incorrect because all inertial frames must move at the speed of light.
tworitdash
108
I have come across a questions which reads "Why does even photon travel?". After reading special and general theory of relativity, this one bugs me all over. For a particle moving closer to speed of light, clock slows down and the space around it contracts. I see a photon travel and I see things around me, because my velocity is much low and and I experience time. However, for a photon, clock doesn't move at all and it doesn't really know what is space (because it is contracted to the maximum). I see light generated from a source and reaching a destination, but a photon doesn't even experience all that. Is the entire universe is a point for a photon? If that's so, where does it come from? Is there any higher dimension, where someone is generating it for us, because for me it is very peculiar and nothing else travels exactly at the speed of light. How's it so?
This is a common pop science misconception. The correct statement is that the concept of "reference frame" with clocks and rulers does not apply to a photon. The Lorentz transformation is not well-defined for ##v = c## so the concepts of "length contraction" and "time dilation" cannot be applied to photons.
Please read our FAQ article:
https://www.physicsforums.com/threads/rest-frame-of-a-photon.511170/
Likes tworitdash
This statement is based on the misapprehension that length contraction and time dilation formulae apply to an inertial frame moving at the speed of light. This is wrong. There is no such frame in relativity - it is self-contradictory, since light would have to be both at rest and doing 3×108m/s.
Any attempt to describe "the perspective of a photon" will therefore fail, and any conclusions drawn from this line of thinking are nonsense.
Likes tworitdash
Well, to start with, "for a photon" is a statement meaning that you can transform to its rest frame and observe. But you can't. Also, length contraction is only in the direction of movement, not in all directions. So if you approach c the universe is only contracted in 1 direction.
Likes tworitdash
So, as in all reference frames, light travels with the speed c, a reference frame which is at rest with respect to it is simply not possible as far as I understand from this answer and all other answers as well. Is my understanding correct?
Likes nitsuj
Yes. The fundamental issue is that the equations for length contraction and time dilation are not defined for light (or anything traveling at or beyond the speed of light). These phenomena apply to sub-light velocities only.
The examples of "all lengths being 0 at the speed of light" or "time stopping at the speed of light" are invalid extrapolations of the equations. These are rife in popular science books and videos but are not found in undergraduate textbooks on SR.
Likes Ibix
Note that if you had a frame of reference in which a light beam were at rest, the light beam would would not be moving at speed ##c## in that frame. But a beam of light must travel at speed ##c## in all inertial reference frames, that is the basis upon which the theory describing time dilation and length contraction is constructed.
No there are not. You can construct theories in which photons have mass and therefore do not travel at a defined speed. The classical version is the Proca potentials, from which you recover Maxwell's equations if you let the mass be zero.
There are implications to a non-zero photon mass, which allow us to measure it. Results are consistent with zero mass, and the upper bound is something like 10-54kg, I believe.
It's worth noting that something that does travel at c must travel at c in all frames in relativity, by hypothesis. Howevern we are not, and cannot be, 100% certain that anything travels at c.
Likes tworitdash
Quite interesting though. Thank you!
FAQ: Photon Travel: Is Our Universe a Single Point?
1. What is photon travel and how does it relate to the concept of our universe being a single point?
Photon travel refers to the movement of photons, which are particles of light. The idea of our universe being a single point, also known as the Big Bang theory, suggests that at the beginning of the universe, all matter and energy were concentrated in a single point and then rapidly expanded. Photons played a crucial role in this expansion, as they were the first particles to be created and travel through the expanding universe.
2. How does the speed of light impact our understanding of photon travel?
The speed of light, which is approximately 299,792,458 meters per second, is a fundamental constant in the universe. It is the maximum speed at which any object, including photons, can travel. This means that photons travel at the speed of light and cannot go any faster. This speed limit has important implications for our understanding of the universe and the concept of a single point origin.
3. Can we observe photon travel in action?
Yes, we can observe photon travel in action through various means. For example, when we look at distant objects in the night sky, we are seeing photons that have traveled for millions or billions of years to reach our eyes. We can also observe the effects of photon travel in phenomena such as the redshift of light from distant galaxies, which is caused by the expansion of the universe.
4. How does the concept of a single point universe relate to the theory of relativity?
The theory of relativity, developed by Albert Einstein, describes the relationship between space and time and how they are affected by the presence of matter and energy. It is a crucial component of our understanding of the universe, and it is compatible with the concept of a single point origin. In fact, the equations of general relativity predict that the universe started from a singularity, a point of infinite density and curvature.
5. Are there any theories that challenge the idea of our universe being a single point?
Yes, there are alternative theories that challenge the Big Bang theory and the concept of a single point origin. These include the steady-state theory, which suggests that the universe has always existed and is constantly expanding, and the oscillating universe theory, which proposes that the universe goes through cycles of expansion and contraction. However, the evidence for the Big Bang and the concept of a single point origin is widely accepted by the scientific community.
