Photon-Wave Duality: Why can't they be separated?
  • B
  • Thread starter MittyWalter
  • Tags
    Duality
In summary, the conversation discusses the concept of wave-particle duality and questions its interpretation in relation to photons. The speakers discuss the idea that photons are particles that emit waves rather than being both particles and waves themselves. They also mention that current theories and experiments do not support this interpretation and suggest further reading to gain a better understanding.
MittyWalter
Hi!
So the whole Photon-Wave Duality phenomenon really bothers me. I found this little video earlier today:
I'm far more comfortable with reality *being* reality. You're either here or there. Every instant contains a single reality. You cannot be in two places at once, nor can you follow two paths at the same time. If you wind up in California, it's because you either drove or flew there. Not both.
And the observation that you are in Cali is totally separate from how you got there.
I don't question the observations behind photon-wave duality, but I wonder if the *interpretation* of the observations could be wrong?
Instead of saying photons are both particles ~and~ waves, wouldn't it make more sense to say photons are particles that ~emit~ waves?
Maybe "emit" is too specific, so let me rephrase:
Wouldn't it be more logical if Photons were surrounded by and/or traveling with light waves?
If you separate cause (photons as particles) from effect (waves associated with that photon) and say that photons are surrounded by lightwaves, you can observe both without also having to believe in unicorns (multiple realities).
While I watched the video, stopped it at each observation point to ask:
If the photo *itself* was surrounded by waves, could that explain the observation?
At 0:55:
Particle detectors prove that a photon does exist and will only go thru one door or the other (cause). But as soon as you catch it, the interference (effect) goes away. This doesn't make sense to me, unless the two are separated.
If that photon is traveling with it's own waves and you catch it all by itself, of course there would be no other photon (+waves) to interfere with the first one. And if you could truly isolate a single photo and catch it, the interference pattern would be limited by the location of the photon at the exact moment you caught it.
At 2:00:
If you set the device to look for a particle, a particle appears and it goes thru one door or the other (not both). If you set the device to look for waves, then waves are observed and they go thru both doors. Makes no sense again, to me anyway.
Unless you consider that the photon is surrounded by a globe of light waves. And those waves extend out from the center, wide enough to go thru both doors. If the photon is headed toward that back wall, so too is the wavy globe that surrounds it. Waves off to the east and west will still travel thru both doors, regardless of which door the particle goes thru.
Please can someone explain why a photon must be BOTH a particle and a wave? Vs simply a particle that travels with waves?
Thanks,
Mitty Walters
Unfortunately, the video is misleading, to say the least. If you fly to San Francisco, you fly to San Francisco. You don't find out later that you went by car: unless you've been hallucinating.
You could try this instead:
It does last an hour, but it may be an hour well spent.
You may be suprised to learn that most Quantum Mechanics textbooks don't mention the wave-particle duality at all. One of the most popular books by Griffiths only mentions it in the Afterword, as a historical footnote.
Your own personal theorising is, sadly, is just a guess based on nothing of any mathematical or experimental substance. This thread will probably get shut down, as it isn't allowed to this forum.
Try the Feynman lecture is my advice.
Likes bhobba and Naman Jain Kota
Unless I'm mistaken, in Quantum Electrodynamics, the theory that is actually used to describe fundamental particles like electrons and photons, there is no duality. I don't know the details of why, though.
Likes bhobba
Photons, electrons etc. are neither waves nor particles. Both are analogues from the macroscopic world. They make sense because a wave function describes them and their behavior in most experiments. At the same time, the particle model is also suited in some cases. I think the latter is mainly a historic relic from the times of Rutherford and Bohr. The fact, that they are described by wave functions doesn't turn them into waves. A spring pendulum is also described by a wave function and I don't see a wave there.
These models are used to help us understand what otherwise cannot be understood, since we don't see it and it behaves completely different to the objects we are used to. In the end we are left with the mathematical description alone, wave functions and operators. Personally I'd wish we learned the mathematics rather than being imposed on pictures we later will have to forget again, or even worse, forced to combine via a virtual duality. The easiest way is to accept, that these "particles" are simply something different.
Likes afcsimoes, bhobba and Naman Jain Kota
First, no one knows "why" the universe is the way it is. Physics attempts to describe the universe, not explain "why". It does that with theories. Yes, the theories can explain some "whys" - but not all.
Theories such as what you mention do not accurately describe photons. Theories which contain elements that are commonly referred to as "wave-particle duality" or "path integral" are much more effective. The Heisenberg Uncertainty Principle is a specific mathematical element which can represent wave-particle duality. Feynman's path integral formulation is also a mathematical treatment (in your version, the many ways to get to California).
You can probably imagine that current physical theories are quite good at predicting the results of actual experiments. That outweighs everything else, including your preferences. There are many modern experiments that demonstrate reality does not have the attributes you think it has. I would recommend that you learn more about this fascinating area by reading a few books, as that will help you see the persuasive arguments involved.
Do you have any recommendations, DrChinese? I might be interested in reading them as well.
I was afraid of being asked that! My favorites are too old! (On the other hand, the laws of physics haven't changed much recently...)
Steven Weinberg's "The First Three Minutes" (1977, updated as of 1993)
https://www.amazon.com/dp/0465024378/?tag=pfamazon01-20
There are newer ones, but I usually don't recommend ones I haven't personally read. Below is newer (2003); more specialized but covers a lot of relevant material along the way:
https://www.amazon.com/dp/B0035G02GI/?tag=pfamazon01-20
Maybe someone else has a few good recommendations too... :smile:
Likes Drakkith
Well i really really wanted to sum up what i understood, please point if i interpreted it wrong.
So basically we don't know what electromagnetic radiation is or what matter is.
All we do is make a theory for matter that is described by a wave function,operators and all and we consider it particle (what is a particle?? i mean definition). We get accurate results but this must not mean this is the actual picture. It's just our way to solve and get answers. Moreover we do sometimes mention wave particle duality, though we don't take it's mathematical account into our theory.
For Photons we have path integral formulation related to quantum field theory (i just googled it!). Thats a good way of describing photons. Even for particles i guess. We consider them to be fields (probably i just looked on google now), and that may not even be happening truly in world. But its more accurate that quantum physics.
yes, yes quiet right. very good - and if the answers correctly predict nature what else do you need to know?
If you know all of its properties and how it behaves, do you not know what it is?
How would you know if a model is the actual picture? If it is accurate enough, there's no way to tell the difference between the model and "actual reality".
Likes DrChinese
So we can confidently say everything exist in form of fields (or whatever quantum field theory is about)!
But the quantum particle model of wave function, are both equivalent? One of those two must be correct right.
What is the quantum particle model?
Sorry for lack of clear expression, basically i meant that a particle is described by its wavefunction, probabilities are linked to a wavefunction. I meant the quantum mechanics as given in griffith's book. We don't consider any types of field in that mechanics.
And yeah I don't have any idea of quantum field theory, so i may have been messing it up :P
there is more than one theory with different constraints.
QFT is the broader theory that explains the behaviour of quantum scale objects with less constraints built in.
the simpler theory with more constraints built in would be Schrodinger's wave mechanics.
Likes Naman Jain Kota
My point is that we can certainly do better than say that we don't know what EM radiation and matter is.
Likes fresh_42
There is a well-known phrase: the map is not the territory. Theories are the map. They are useful descriptions. You will find that every theory leaves something to be desired.
So don't confuse ANY theory with what it describes. You could never say a theory is the "actual picture".
Likes Naman Jain Kota, fresh_42 and PeroK
Wow, thanks for all the thoughtful responses! And most especially for all the suggested reading. I have a cup of coffee and can spare an hour, so I'll start my journey with PeroK's movie.
My take from what you guys said:
• The topic of Wave–particle duality is antiquated
• The video in my OP is misleading because it fails to acknowledge other more modern takes
• There are plenty of other theories that can mathematically predict the behaviors (w/o conflict?)
Einstein put it this way:
"It seems as though we must use sometimes the one theory and sometimes the other, while at times we may use either. We are faced with a new kind of difficulty. We have two contradictory pictures of reality; separately neither of them fully explains the phenomena of light, but together they do."
PeroK, you said that my suggestion was "just a guess based on nothing of any mathematical or experimental substance." The first part is true, but the second is not. Granted I did not perform the experiments that underlay Einsteins comments above, but my guess was based some pretty solid work done by Planck, Bohr, and many others.
As a reminder, my guess was that photons are particles surrounded by a globe of waves. The circumference of that globe becomes larger or smaller depending on the excitation of the particle.
I realize I need to dig deeper, read and learn. And, ultimately, fresh_42's take is where I may end up: "The easiest way is to accept, that these "particles" are simply something different."
But I'd still like to know of any theory that accounts for both? Houlahound points to QTF
Excellent. I get that, I really do. I was just taking a shot drawing my own map! :D
"A globe of waves" means nothing to me. You can in fact think about the wave-particle duality another way. What actually is a wave anyway? If you flick a piece of rope you see a wave moving along the rope. But the wave is just each part of the rope in turn moving up and down in response to the previous section of rope. Nothing physical is actually moving along the rope. So what exactly is the wave?
Perhaps a pulse of energy? And maybe that's starting to sound almost particle-like?
I picture something like this:
http://diygravity.com/circle_array_wavy.jpg
And yes, it would be something like energy pulses spinning off the particle.
This doesn't look like a useful picture to me.
A good layman's presentation of the basics of quantum electrodynamics, which goes into some detail about how to "visualize" the way photons work in QM, is Feynman's QED: The Strange Theory of Light and Matter.
Likes MittyWalter
DrChinese said:
First, no one knows "why" the universe is the way it is. .
The nearest we can come to these days is symmetry. But whether it should be taught that way is the subject of a current thread with various (valid) views. Overall, and this is not my view, most are not fans of the idea - at least of the book that attempted to do it.
Thankaks
Bill
Likes MittyWalter
fresh_42 said:
Here's an interesting article about the particle nature of electrons (at 15 mK):
http://phys.org/news/2016-11-absolute-electrons-quantum-nature.html
I think they are inflating the importance of their measurement a bit too much here. Bolting a STM to a dilution fridge is tricky but has been done before.
Moreover, the "particle nature of electrons" is there to see whenever you do an electrical measurement which exhibits shot noise (which is present in an ordinary op-amp). You certainly do not need conditions as extreme as this.
Also, the "extreme" version of an electrical current defined by transport if individual electrons would be an electron pump, and they have been around for some 25 years or so (they will be used to realize the Ampere after the re-definition of the SI in a couple of year).
Likes Nugatory
This problem is as much philosophical as it is scientifically objective. So called wave-particle duality is an illusion that results when you try to apply classical thinking to a non classical problem. In the case of wave-particle duality whether a photon looks like a wave or a particle depends on the nature of the experiment.
There is a huge difference between knowing what something does and knowing what something is. Most scientific theories are behavioral in nature. By this I mean that the theory, or model if you will, is a description of how something behaves. Newtonian mechanics is an excellent example of this. Newton provided an astonishingly accurate description of how gravitation and momentum behave but he admitted that he did not understand why it behaved that way. He detailed the behavior but could not reveal the underlying mechanism. When you know what something does you have created a model that bears a useful relationship to an underlying reality. But it's as if the reality is in a box that cannot be opened. You can perform various experiments on the box and obtain increasingly accurate predictions of its behavior under various circumstances. But if you cannot open the box the true mechanism will forever remain unknown. Quantum physics takes this a bit further. If you force the box to open you shatter its contents leaving only fragments of what was once intact inside. Particle accelerators are an example of this.
MittyWalter said:
Hi!
At 0:55:
At 2:00:
Thanks,
Mitty Walters
Much of the confusion and mystery surrounding wave-particle duality can be resolved by the following terse statement (e.g. by John Polinghorne): The waves in wave-particle duality are waves of probability. Thus in a two-slit experiment, especially if done gradually one photon at a time, photons are and behave like particles, but their distribution in space and time can be wavy. Or think of a crime wave: The criminals and crimes are never waves, and they do not turn into waves or radiate waves, not are they surrounded by waves, but if we graph their appearance over a period if time on a map, we may find one or more waves. One fine point is that waves of probability can show interference and diffraction. So photons do not interfere with each other, but the waves that describe their space-time locations can do so. Also do not be mislead by wave lengths that determine the color of light; these are a reflection of their energy and do not invoke any duality. (De Broglie got hung up on this.)
I'm surprised there are no references to Ballentine (see this thread).
Oh man, wait till you get to quantum eraser:
Likes bhobba
Ballentine is truth.
You learn Wave-Particle duality is a myth.
Thanks
Bill
  • #31
When you finish measuring the location of particle, it certainly looks like a particle - you have found something at one position in space. When you wait a bit and then measure its position again, it is still a particle. No question about it - it is a particle. When you then do this several times, and reflect on what mathematics would describe where you are finding the particle each time, you (actually physicists 100 years ago) discover it looks like a wave spread out from the particle, around any obstacles, and the probability that you find the particle in a certain place is related to the amplitude of that wave.
The formula for a wave looks like d2y/dx2 = y, but it turns out the wave that is guiding the particle has a factor of "i" (the square root of negative one). To figure out the shape of the wave, you have to know about the forces acting on the particle (the "Hamiltonian") and use that to solve the Schrodinger equation. When you solve the Schodinger equation for the "wavefunction", and you try to measure the momentum of the particle according to the Rules of Quantum Mechanics, you might be surprised to find the solution describes a wave. I think the technical way to say it is that the eigenvalues of momentum (possible values the particle's momentum might take) are frequencies of a wave.
So there are some aspects of particles that are wavelike in their nature. What if you could look at an electron - would it look fuzzy and spread out like a wave, or would you never be able to see it because it would be a little point no matter how hard you looked at it? Well, as far as they've gotten, it does look just like a point ... but it is probably made up of smaller things (some think little open vibrating strings). We probably won't be able to make light waves of a high-enough frequency to see the details of an electron in our lifetime, and QM and Relativity famously disagree on how the parts of something that tiny would look and behave. String theory's math bases the behavior on the math of ordinary string (massive point particles connected by massless spring-like forces). Electrons do seem to be spinning all the time, though, because they have magnetic fields, and one can think of these fields being cause by the electrical charge of the electron spinning around some axis. I think most experts would correct me and say that the spinning might not be real - but according to famous theoretical physicist Leonard Susskind in a Stanford lecture I saw, it could be that they are extended, spinning objects.
  • #32
Is that statement: theory, the actual picture, or something else?
  • #33
Considering the comparison of a light source being like a group of simultaneously dropped balls...Then how could 'falling' photons influence each other?
Isn't it most likely the slit experiment phenomena isn't resulting from 'photon interaction'?
But by simply glancing off the slits?
As a function of their 'then oriented' structure; varying with time?
  • #34
@MittyWalter : I'm going back to the very beginning which I am sure is the source of all your problems. Until you are able to wrap your head around the concept of quantum superposition, you will never get over the hump of not being able to understand what quantum theory is.
Please note also that Nature has no obligation to present herself in ways that you are "comfortable" with.
Zz.
  • #35
Closed temporarily for Moderation...
Likes bhobba
Related to Photon-Wave Duality: Why can't they be separated?
1. What is photon-wave duality?
Photon-wave duality is the concept that light can exhibit both particle-like and wave-like behavior. This means that light can act as a stream of particles (photons) or as a wave, depending on how it is observed or measured.
2. Why can't photons and waves be separated?
Photons and waves cannot be separated because they are two different ways of describing the same phenomenon. In certain experiments, light behaves like a wave, while in others it behaves like a particle. This duality is a fundamental property of light and cannot be separated.
3. How does the double-slit experiment demonstrate photon-wave duality?
The double-slit experiment involves shining a beam of light through two parallel slits. When observed, the light behaves like a wave and creates an interference pattern on a screen behind the slits. However, when unobserved, the light behaves like a stream of particles and creates two distinct bands on the screen. This experiment demonstrates the dual nature of light as both a wave and a particle.
4. What is the significance of photon-wave duality?
The concept of photon-wave duality revolutionized our understanding of light and the behavior of particles at the atomic level. It also led to the development of quantum mechanics, which has had a significant impact on modern technology and our understanding of the universe.
5. Can other particles exhibit wave-particle duality?
Yes, other particles such as electrons, protons, and even large molecules can exhibit wave-particle duality. This phenomenon is not limited to light and is a fundamental aspect of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
