Photons emitted by heated objects
  • Thread starter Amyriel
  • Tags
    Photons
In summary, the conversation discussed the emission of photons from an object at finite temperature due to its thermal energy. These photons are emitted according to Planck's law and can be influenced by factors such as the object's contact with a heat bath, degrees of freedom, and surface properties. The question was specifically about the photons emitted by jumping electrons, but it was also noted that other degrees of freedom contribute to thermal radiation. Additionally, the conversation touched on factors such as roughness, angle dependency, and polarization that can affect the emission and reflection of radiation from an object.
Amyriel
Hello everyone,
I have a question. Electrons jumps up the energy level by absorbing a photon and down releasing it, giving off a characteristic spectrum. Then, are the photons released when an object is been heated up due to intermolecular forces, since they are of a full spectrum? Is the kinetic energy of the atoms enough to make the electrons jumps or do they absolutely require a photon?
Thank you :)
Science news on Phys.org
An object at finite temperature emits photons according to Planck's law.
See https://en.wikipedia.org/wiki/Black-body_radiation.
If these photons escape the body will cool down to absolute zero unless it is in contact with a heat bath at some temperature. That contact will keep the excited states populated causing the emission, indeed without the need for photons.
The photons created from the kinetic energy of the atoms aren't due to electrons changing energy levels, but simply due to the fact that the atoms are vibrating/oscillating. An oscillating charge will emit photons at a frequency equal to that of the oscillation.
Likes davenn
The question was specifically after photons emitted by jumping electrons.
But yes other degrees of freedom of the object also contribute to the thermal radiation.
Also the degrees of freedom of a real object do not populate the energy spectrum uniformly.
This will lead to deviations from Planck's law, which assumes 100% absorption at all wave lengths.
And then there is still reflection of incident radiation to be considered.
Further aspects:
roughness of the surface, which may cause diffuse scattering
angle dependency of emitted and reflected radiation
angle dependent polarization
FAQ: Photons emitted by heated objects
What are photons?
Photons are particles of light that are emitted from heated objects. They have no mass and travel at the speed of light.
How are photons emitted by heated objects?
When an object is heated, the atoms within it gain energy and begin to vibrate. As the atoms vibrate, they release photons in the form of electromagnetic radiation.
What is the relationship between temperature and the number of photons emitted?
The number of photons emitted by a heated object is directly proportional to its temperature. As the temperature increases, so does the energy of the atoms and the number of photons emitted.
Can photons be detected?
Yes, photons can be detected using specialized equipment such as photodetectors or light sensors. These devices are designed to measure the energy and frequency of photons.
How do photons contribute to the transfer of heat?
Photons play a crucial role in the transfer of heat. As they are emitted from a heated object, they collide with other particles and transfer their energy, resulting in an increase in the object's temperature. This process is known as thermal radiation.
10K
20K
