Photons interfering with themselves-double slit experiment
In summary, the uncertainty principle states that it is impossible to know both the position and the momentum of a particle with absolute certainty.
Strafespar
47
How can a photon, or any other particle, interfere with itself? What does the uncertainty principle have to do with it? Why can't a device be used to track particles/waves? Please help with real answers! Thanks!
Question 1. We do not know, perhaps they are not particles after all.
Question 2. The uncertainty principle is a consequence of the probability wave function, or wave mechanics in general. Anything that exhibits wave like behavior has an associated uncertainty between some observables.
Question 3. A measurement device can track particles.
I ment, when we measure a electron it collapses the wave function. How does that work?
Answer that and you'll win a Nobel Prize.
haha, I'll work on it.
Don't trust Nisse. You don't get Nobel prize for trivial things.
And indeed it is trivial. You reduce ensemble with your measurement.
You separate photons (I would like to use photons instead of electrons) onto different paths for later detection or you do detect some and do not detect other photons.
If you detect all photons from original ensemble then it's unitary evolution, nothing happens with wavefunction.
The wave function is a set of probabilities of finding a particle in a specific location. If we find the particle in a specific location it is no longer logical to specify the probabilities in other space locations but rather set the location we know it to be to 1 and the rest to 0.
The function collapses, out of definition.
ok from what i can intefere from the various topics regarding the doyuble slit exp. is that
1) Photon causes inference pattern cool
2) If I fire just a single photon ok just one the It also produces inference :S now that will mean that a photon is passing through the two slits simultaneously ?? I.e that it is existing at two points at the same time :S can some one elaborate ?
This has been answered many times (including by me recently)
Any particle has a wave property associated with it (we don't know how/why) which passes through both slits and is responsible for the interference pattern.
If you attempt to detect which slit the "particle" passes through you must either collapse the wave to another wave localised near one of the slits (otherwise your measurement doesn't tell you which slit) or you cause the slits' positions to become uncertain (eg by attempting to measure a momentum change of a slit as the particle passes near it) so as to destroy the inteference.
There are clever alternative attempts to detect "which-way" information such as using an asymmetric slit arrangement and measuring the time of transit to determine which slit, but in all cases the interference gets destroyed.
It's a puzzle, but it happens, no one can really explain why, the solution is looking like it may emerge from the extra dimensional structure of space suggested by string theory, but no one really knows, and the phenomena is best accepted as a "fact of nature" for now.
^^ every thread has the same answer, as far as what I can gather,
collapse = 100% probabilty of finding the particle. If we do that then the inference is gone isn't it ?
So, basically measurement causes the dissapearence of the inference, the seems implausibl :(
now still even if we don't measure, then the inference means the particle is passing both the slits at the same time IS IT SO OR NOT ? please answer this specific point as this creates doubt.
What is a particle? Plz answer specific point as this creates doubt.
^ photon.
phyfreak said:
^ photon.
ok, well explain what a photon is then :smile:
You probably won't be able to, since no one knows.
However you can still say a lot about what photons do, including producing interference effects (over time) in single emission double slit experiments (single emission confirmed by single detection in photomultiplier)
If you want a state-of-the-art explanation then you need to study quantum field theory, but you still won't get an answer to the question "does the photon go through both slits", you will however get an excellent mathematical model to calculate in more detail what the photon does.
Ok so there have been experiments where only ONE photon was fired and it produced an inference OR we can't define what is " ONE photon " so there is no possibility of conducting an experiment with a single photon ?
afaik photons r packets of lights isn't it ? I believed that the same single packet of light may somehow maybe split a good way to check this would have been to check the brightness of the inference wrt to the orignal source :)as for the QFT i don't know if I have that much time :) I am a law student hence I am really bad with numbers but good with logic so what is do is skip the mathematical part and jump to the logical part I know this is faulty but numbers seems to go over head for me, w/o the I don't know If study of such advanced concepts are possibl.
Anyways thanks for explaining things to a layman like me :)
Single photon experiments have been done for years, here's a slightly modified version where a single pair of entangled photons is emitted (but only one of them travels to the slits) in a clever attempt to get "which way" information (ie. detect which slit a single photon passed through)
http://grad.physics.sunysb.edu/~amarch/
of course, this fails (the interference is not seen if "which way" information is obtained) :smile:
^ Thank you for the link, I clarified some misconceptions and is forcing me to believe in non locality but still I hold the the LHV theory supported by Eientien
The paper clearly stated that a photon if fired singly and then won't be able to produce the inference but over some time it will i.e the photon is passing one slit but we can't know which one. This is rather strange, I hope a quantum level extra dimention maybe able to solve th rpoblem rather than complex and implausibl theory like the MWI or copehangen.
Obviously a single photon doesn't produce an interference pattern, but if you send many single photons one after the other a spatial pattern of dots emerge at the detector, which shows characteristic interference bands. There wlll be bands where no photons ever hit, which is not explainable without single-photon interference. EDIT: In practice the forbidden bands will more likely have reduced intensity rather than zero hits
The scientific consensus is that Einstein was (clearly) wrong about QM, in that he hoped a local hidden statistical mechanism would explain quantum behaviour.
The only reason people are still speculating is that the real mechanism is still unknown and is in fact looking like it may be something quite incredible, probably explained by projections from higher dimensional spaces (branes) onto our naive assumption of a 3-dimensional world.
So that the locality is restored in the higher dimensions but is broken when projected onto our observable 3-D space.
Single photon is single "click" in photon detector.
But there does not seem to be practical way to conduct experiment with single photon because you will have difficulties first to fire one single photon and then to detect this one single photon with considerable efficiency (it can end up at many different places on screen and it can hit the barrier not making trough any of the two slits).
So in any practical experiment you just lower the rate of photons coming from the source.
If you consider light to be quantized then single photon can't be split.
Even if you consider that it splits in two parts then why should both parts end up at the same spot on screen?
Anyways there are performed double-slit experiments with fullerene molecules and in that case you would have to stretch you imagination quite far to consider that the molecule itself somehow splits.
FAQ: Photons interfering with themselves-double slit experiment
What is the double slit experiment?
The double slit experiment is a classic experiment in quantum mechanics that investigates the wave-particle duality of light. It involves shining a beam of light through two parallel slits and observing the resulting interference pattern on a screen behind the slits.
How do photons interfere with themselves in the double slit experiment?
In the double slit experiment, photons (or particles of light) are sent through the two slits and then they interfere with each other, creating an interference pattern on the screen. This is possible because photons exhibit both wave-like and particle-like behavior, allowing them to interfere with themselves.
What is the significance of photons interfering with themselves in the double slit experiment?
The double slit experiment provides evidence for the wave-particle duality of light, which is a fundamental concept in quantum mechanics. It also demonstrates the strangeness of the quantum world, where particles can behave like waves and interfere with themselves.
Can the double slit experiment be done with other particles besides photons?
Yes, the double slit experiment has been successfully performed with other particles, such as electrons, protons, and even large molecules. This further supports the wave-particle duality of matter and shows that the phenomenon of interference is not limited to light.
What practical applications does the double slit experiment have?
The double slit experiment has led to the development of technologies such as holography and diffraction gratings. It also has implications for quantum computing and cryptography. Additionally, it has helped scientists better understand the nature of light and matter, leading to advancements in the field of quantum mechanics.
