Photons of light emitted within the D-lines per second?
In summary, the energy of one photon of light emitted within the D-lines of a sodium lamp with a wavelength of 589 nm is 3.4 * 10-19 J. In a 200 W sodium street lamp, with 30% of input electrical energy being emitted within the D-lines, the number of photons emitted per second is 1.8 * 1020 s-1. The calculation for this is 60 W / (3.4 * 10-19 J) = 1.8 * 1020 s-1. Working with units can help to spot errors in calculations.
moenste
711
(a) Calculate the energy of one photon of light emitted within the D-lines of a sodium lamp if the wavelength of the D-lines is 589 nm.
(b) In a 200 W sodium street lamp, 30% of input electrical energy is emitted within the D-lines. How many photons of light are emitted within the D-lines per second?
(h = 6.6 * 10-34 J s, c = 3 * 108 m s-1)
Answers: (a) 3.4 * 10-19 J, (b) 1.8 * 1020 s-1
2. The attempt at a solution
(a) f = c / λ = 3 * 108 / 589 * 10-9 = 5.09 * 1014 Hz
E = hf = 6.6 * 10-34 * 5.09 * 1014 = 3.4 * 10-19 J
(b) No idea what to begin with. Any help please?
If one apple has a mass of 200 g and I give you 2000 g of apples per second, how many apples per second do you get? How did you calculate that?
What changes if you receive only 30% of the apples I give away?
Likes moenste
(i) I get 2,000 / 200 = 10 apples per second.
(ii) It's either 2,000 * .3 = 600 g -> 600 / 200 = 3 apples per second or 10 * .3 = 3 apples per second.
200 * 0.3 = 60 W
60 * 3 * 108 = 1.8 * 1010 s-1
But the answer is 1.8 * 1020 s-1.
moenste said:
200 * 0.3 = 60 W
Missing units, but the result is right.
The units are wrong, you multiply a power with a speed - the result cannot be a frequency.
Why do you take the speed of light here? It is unrelated to this subquestion.
In general, working with units helps to spot many errors.
Likes moenste
A lamp supplies 200 W of energy. 30% of this energy is emitted within the D-lines. It is 200 W * 0.3 = 60 W.
Energy of one photon of light emitted within the D-lines = 3.4 * 10-19 J.
60 W / 3.4 * 10-19 J = 1.8 * 1020 s-1.
Correct.
Just a notation issue: a/b * c is usually read as (a/b)*c which is not what you meant here.
It is better to put brackets around the denominator: 60 W / (3.4 * 10-19 J)
Likes moenste
Related to Photons of light emitted within the D-lines per second?
1. What are photons of light emitted within the D-lines per second?
Photons of light emitted within the D-lines per second refer to the specific wavelengths of light that are emitted by atoms or molecules in the form of electromagnetic energy. These wavelengths fall within the visible light spectrum and are commonly observed as colored lines in spectroscopy experiments.
2. How are photons of light emitted within the D-lines per second measured?
Photons of light emitted within the D-lines per second can be measured using a spectrophotometer, which analyzes the intensity of light at different wavelengths. The number of photons emitted within the D-lines per second can also be calculated by measuring the energy of the photons and the time interval in which they are emitted.
3. What is the significance of the D-lines in spectroscopy?
The D-lines, also known as the sodium doublet, are two closely spaced lines in the visible light spectrum that are emitted by sodium atoms. These lines have a well-defined wavelength and are used as a reference for calibrating spectroscopy instruments and identifying the presence of sodium in a sample.
4. Can photons of light emitted within the D-lines per second be manipulated?
Yes, photons of light emitted within the D-lines per second can be manipulated using various methods such as changing the temperature or pressure of the emitting source, applying an electric or magnetic field, or interacting with other particles. These manipulations can alter the energy and wavelength of the emitted photons.
5. What is the practical application of studying photons of light emitted within the D-lines per second?
The study of photons of light emitted within the D-lines per second has many practical applications, including in spectroscopy, astronomy, and telecommunications. By analyzing the wavelengths and energy of these photons, scientists can gain valuable information about the composition and properties of different substances and objects, and also develop advanced technologies for communication and information processing.
