Photons striking a camera sensor?
In summary, to produce a clear image in low light, an exposure needs at least 100 photons per second.
Ralf66
I am curious as to roughly how many photons strike a camera sensor (e.g. a DSLR) in dim light, where the camera can form an image?
Also how many photons are hitting a photosite for it to be triggered?
and... how many photons have to hit a human rod (or cone) cell for it to be triggered and send a signal to the nerve?
Science news on Phys.org
Offhand I'd say a very grainy image needs a SNR of around 5 at bare minimum. Since there are multiple sources of noise, it's hard to give you an exact number of photons needed for this. However, to simplify the situation, let's assume there's only shot noise, which is the randomness of the arrival of the photons themselves.
A signal to noise ratio is expressed as SNR = N / √N, where N is the number of photons detected by each pixel. This means that each pixel has its own SNR.
To get an SNR of at least 5, N needs to be at least 25. In other words, we need at least 25 photons if we want our pixel to have an SNR of at least 5. Let's say we have a 10 megapixel sensor. So, 25 photons per pixel times 10 million pixels is 250 million photons total for the sensor.
In reality we would need even more since shot noise is only one source of noise.
CCD and CMOS photosites aren't 'triggered', but instead detect photons by accumulating electrons excited when photons strike the photosite. Each photon excites one electron, so they can potentially detect individual photons. However the real life situation is not that simple. In addition to shot noise, the electrons in each photosite have thermal energy and this causes 'thermal noise' where an electron is excited high enough by the thermal energy to be 'detected'. Plus the electronics themselves can cause noise too. So when the sensor is read after an exposure is taken, you have combination of electrons excited by photons mixed in with electron excited by other means. In bright light the number of photons hitting the sensor per unit of time is so high that the signal overwhelmingly dominates over the noise. But in low light conditions you have to take longer exposures and/or take other steps to get a good SNR and thus a good image.
Likes Spinnor
The quantum efficiency of most sensors is significantly below 100%, so you need even more photons.
The eye can be surprisingly sensitive. At perfect dark adaption and with a very collimated light source of the right color, something like 100 photons over a very short time can be sufficient to get a clear impression of light. Sometimes even fewer. See this description and the sources there for details.
FAQ: Photons striking a camera sensor?
1. What are photons?
Photons are small packets of energy that make up electromagnetic radiation, including visible light. They have no mass and travel at the speed of light.
2. How do photons strike a camera sensor?
Photons enter a camera through the lens and strike a photosensitive material, usually a semiconductor such as silicon, in the camera sensor. This material converts the energy from the photons into electrical signals.
3. How does the camera sensor detect photons?
The camera sensor is made up of millions of tiny light-sensitive units called pixels. When a photon strikes a pixel, it creates an electrical charge. This charge is then measured and converted into a digital image by the camera's processor.
4. Can photons be blocked or absorbed by the camera sensor?
Yes, the camera sensor can absorb or block photons depending on its material and design. Some materials are more sensitive to certain wavelengths of light, while others may have filters to block out unwanted wavelengths.
5. How does the number of photons affect the image quality?
The number of photons that strike the camera sensor affects the image quality in terms of exposure and noise. If there are too few photons, the image may be underexposed and appear dark. Too many photons can result in overexposure and a loss of detail. Additionally, noise can be introduced if there is an imbalance in the number of photons hitting different areas of the sensor.
