Photons transmitted through transparent substances.
In summary, photons entering water are slowed down by the presence of particles, but are still able to travel through the material relatively undisturbed.
Infrasound
70
I have noticed in the past that light travels through water relatively undisturbed (I have noticed that there seems to be some small amount of light reflected, but most seems to pass directly through).
How does this happen, in terms of photons encountering particles?
I once thought that the correct explanation might be that the photons simply do not interact with the particles of the water. But I think that this must be wrong, because the light changes it's speed/direction upon entering the water, suggesting that some interaction takes place.
I now imagine a photon entering the water, striking an electron and being absorbed, then being re-emitted by the same electron only to be absorbed by another electron in perhaps the next adjacent atom/molecule. I imagine the process repeating itself from molecule to molecule until the light reaches the other side of the column of water.
Is my mental model of the process anywhere close to being realistic? If not, is there a better way to imagine it.
I think there is a model on your description, but I don't think that is accurate. Maybe someone can elaborate?
ZapperZ has a very useful entry that at least partially answers this question in the Physics forum FAQ.
https://www.physicsforums.com/showthread.php?p=899393
I think the following portion is the key to the model that ZapperZ describes, as it applies to my problem.
"On the other hand, if a photon has an energy beyond the phonon spectrum, then while it can still cause a disturbance of the lattice ions, the solid cannot sustain this vibration, because the phonon mode isn't available. This is similar to trying to oscillate something at a different frequency than the resonance frequency. So the lattice does not absorb this photon and it is re-emitted but with a very slight delay. This, naively, is the origin of the apparent slowdown of the light speed in the material. The emitted photon may encounter other lattice ions as it makes its way through the material and this accumulate the delay." - Posted by ZapperZ in FAQ.
Although this model is intended to describe a solid (i think), it seems to me that it could also possibly describe a liquid in a similar way (perhaps the molecules are close enough to allow molecules to have some influence on each other, creating a spectrum of vibrational modes which would allow for absorption of a wide spectrum of light.)
What about the portion of photons that are reflected? Would this be a condition where photons are absorbed by electrons in surface molecules and re-emitted back in the opposite direction, instead of being transferred forward/through to an electron in an adjacent molecule? (Sort of like dropping something heavy on a trampoline, and having it reflect back at you)
Yes, but again this is not from absorption/re-emission so much as the qualities of the "lattice". Just remind yourself that electrons and protons are themselves very small (of course this is somewhat relative - but their constituents are considered points) so much so that you may as well consider them a vacuum if you ignored field-like effects. As ZapperZ says:
"Almost all of the properties of solids that we are familiar with are the results of the collective properties of the solid as a whole, not the properties of the individual atoms. The same applies to how a photon moves through a solid." Or reflects, for that matter.
FAQ: Photons transmitted through transparent substances.
What is a photon?
A photon is a fundamental particle of light that carries energy and has no mass.
How are photons transmitted through transparent substances?
Photons are transmitted through transparent substances by passing through the material without being absorbed or scattered.
What factors affect the transmission of photons through transparent substances?
The transparency and thickness of the substance, as well as the wavelength and energy of the photons, can affect the transmission of photons through transparent substances.
Can photons be transmitted through all transparent substances?
No, some transparent substances may have absorption bands that prevent certain wavelengths of light, and therefore photons, from passing through.
What are the practical applications of understanding photon transmission through transparent substances?
Understanding how photons are transmitted through transparent substances is important in fields such as optics, materials science, and medicine, as it allows us to manipulate and control light for various purposes, such as creating lenses, developing solar cells, and conducting medical imaging.
