Phys Chems - Request for help with LIF experiment
In summary, the speaker is having some trouble setting up their first LIF experiment, specifically with measuring the nitrogen first positive system using a barrier discharge plasma. They are experiencing signal and scatter into the PMT, despite using a bandpass filter. The speaker has tried using an additional filter and consulting with others, but the issue persists. They are seeking any ideas or help in troubleshooting the problem.
Thermodave
41
I'm setting up my first LIF experiment and I'm having some trouble. I'm measuring the nitrogen first positive system as has been done by numerous groups. The excitation beam is ~618 nm (v=0->4) and the detected fluorescence is around 676 nm (v=4->1). The plan is to use a barrier discharge (RF for now) to create a plasma (~5 torr). I am using an oscilliscope and PMT with a 680/10 nm bandpass filter.
The problem I'm running into is that I"m getting some signal/scatter into the PMT. The filter is sealed very well so I can't see any light getting through it yet the signal goes away when I block the beam. Note that this happens with no plasma. The windows of the discharge cell, which are actually UV windows, seem to create a lot of scatter, but the bandpass should not be allowing any meaningful amount of light through. If I add an additional longpass filter that blocks anything under 650 nm, the result doesn't seem to change. When I use two bandpass filters the measured signal decreases as you would expect. The signal varies from pulse to pulse (at 10 Hz) but that may just be because of the variation in beam power.
This is my first experiment but nobody seems to be able to help me out. Any ideas? Thanks so much for any help.
I would first check the alignment of the excitation beam and make sure it is properly focused on the sample. It is possible that the scattered light is coming from the excitation beam hitting the walls of the discharge cell or other surfaces in the setup.
I would also check the intensity of the excitation beam and make sure it is not too strong, as this can also cause scattering. If the intensity is too high, it may also be saturating the PMT and causing the signal to appear even when the beam is blocked.
Another possibility is that there could be some contamination on the surface of the bandpass filter, which could be causing additional scattering. I would clean the filter carefully and make sure it is free of any dust or debris.
If none of these solutions seem to be working, it may be helpful to consult with other researchers who have successfully conducted LIF experiments with similar setups. They may have some insights or tips that could help troubleshoot the issue.
Overall, it is important to carefully consider all possible sources of scattering and eliminate them one by one until the signal is isolated and only coming from the desired fluorescence. Good luck with your experiment!
FAQ: Phys Chems - Request for help with LIF experiment
1. What is LIF and why is it used in experiments?
LIF stands for Laser-Induced Fluorescence and it is a technique used in physical chemistry experiments to study the properties and behavior of molecules. It involves using a laser to excite a molecule, causing it to emit light at a specific wavelength, which can then be analyzed to gather information about the molecule's structure and dynamics.
2. How does a LIF experiment work?
A LIF experiment typically involves directing a laser beam at a sample of molecules, which causes them to fluoresce. The emitted light is then detected by a spectrophotometer and analyzed to determine the fluorescence intensity and wavelength. This information can provide insights into the molecular structure and behavior.
3. What types of molecules can be studied using LIF?
LIF can be used to study a wide range of molecules, including gases, liquids, and solids. It is particularly useful for studying organic molecules and radicals, as well as certain inorganic molecules. However, the molecule must have a specific electronic transition that can be excited by the laser in order for LIF to be effective.
4. What are the benefits of using LIF in experiments?
LIF offers several advantages over other techniques used in physical chemistry experiments. It is non-destructive, meaning the sample can be reused for multiple experiments. It also provides high sensitivity and selectivity, allowing for the detection and analysis of trace amounts of molecules. Additionally, LIF can be used for real-time monitoring, making it useful for studying dynamic processes.
5. Are there any limitations to using LIF in experiments?
While LIF is a powerful technique, it is not suitable for all types of molecules and experimental conditions. For example, the sample must be in a gaseous or liquid state and there must be a specific electronic transition available for excitation. Additionally, the presence of background fluorescence or scattering can affect the accuracy of the results. Careful experimental design and data analysis are necessary to overcome these limitations and obtain reliable results.
